Front strut boot making hideous noise
Old Apr 26, 2008 | 01:56 PM
greenwar's Avatar
Default Front strut boot making hideous noise
First of all, this is my 2nd post on the first day on this forum.
I recently had the front struts changed on my 04 EP3 hatch. After strut replacement, the front strut boot/bumpstops make hideous noise while going over small bumps. It started with a low key moaning type noise (I know). Now the front left makes noise as if everything is falling apart. Checked all the bolts/nuts (after taking the wheel off) and everything is tightened accordingly. I can't seem to figure out what the issue is. Can it be a bad shock mount? Or may be the spring it's tightened enough to the strut assembly?
Did anybody experience this? My friend and I did the shock replacement ourselves so I can't really take it back to a shop to have it looked.
Some help please, oh btw, I did search and found nothing.
Old Apr 26, 2008 | 03:25 PM
Todd00's Avatar
I said I don't want a title!
Default Re: Front strut boot making hideous noise (greenwar)
Search using different keywords--this is a common problem that comes from assembling the strut incorrectly, installing backwards or leaving something loose.
Old Apr 26, 2008 | 06:11 PM
greenwar's Avatar
Thanks Todd. I found some threads. I will tear it down and tighten the strut top and lube is with lithium grease. Hopefully that would fix the issue.
colton1808
Feb 28, 2018 01:24 PM
eighty6gt
Honda Civic (2001 - 2005)
Mar 31, 2008 08:14 AM
ArchAngel Sabastian
Feb 5, 2002 11:51 AM
Slow&Furious
Nov 15, 2001 05:42 PM
