TPS CEL. Help
Old Apr 26, 2008 | 01:18 PM
Horseofcourse's Avatar
Default TPS CEL. Help
I have a 92 Hatch with an ls-vtec. and i keep getting code seven(TPS) i checked all the ohms and everything after searching on Honda-Tech to fix this problem. But i still have no luck. Anybody Got any ideas? i have tried three throttle bodies already.
Old Apr 26, 2008 | 04:12 PM
HELP!
Old Apr 26, 2008 | 04:22 PM
pdiggitydogg's Avatar
Have you check continuity to the ecu?
The tps checks out, youve used different ones...perhaps the ecu just isnt getting a signal...?
Old Apr 27, 2008 | 01:10 AM
I Checked it out maybe i have my wires mixed up?
Old Apr 27, 2008 | 08:30 AM
Juan_Mitosis's Avatar
Ok. A CEL code mostly means that the part is faulty, OR a faulty connection to that part. Check the wires. Good luck!
Old Apr 27, 2008 | 09:46 AM
zero-one's Avatar
Default Re: (Horseofcourse)
did you try a new or different tps also check if you didnt switch your map sensor and tps sensor plug. they look the same so its a common problem. everytime you do something different make sure you reset your ecu by removing the neg. bat. terminal or taking the fuse off. what does your car do by the way?
Old Apr 27, 2008 | 11:49 AM
Default Re: (zero-one)
Why does everybody on honda-tech think that when someone asks a question they are a 16 year old kid working on there first car. You guys need to quit acting like we are all retarded.
Back to my thread.
Any ideas? Please help and be constructive please.
I dont need posts like this:
"Go Search" (Done it found nothing)
"Check this and that"(Read My thread all the way)
Old Apr 27, 2008 | 08:12 PM
bump
Old Apr 28, 2008 | 08:12 AM
Have you tried a different ecu....?
I dont know what you want anyone to tell you.
Youve tried different TBs. You say youve checked the wiring.
Obviously something is at fault and the ecu is the only option left.
Old Apr 28, 2008 | 07:44 PM
Has anybody had a problem with a phearable.net ecu?
craiger28
Honda Civic (2001 - 2005)
Aug 5, 2012 09:10 AM
andyc_0652
Nov 18, 2010 06:54 PM
steve0527
Dec 11, 2006 05:53 AM
jays93eg6
Sep 25, 2006 03:38 PM
badnan
Mar 12, 2003 04:47 AM
