idle problem
Old Apr 26, 2008 | 12:39 PM
silverdcteg's Avatar
Default idle problem
i have a ej1 with a z6 motor. the idle bounces from 900-1600 after about a minute after start up til the car turns off. i changed the iac twice and changed the t/b. the top hole in the t/b has a leak, u can hear the air being sucked. if i cover the hole with my finger the idle goes normal also the car used to be auto now manuel and theres a auto p28. what could it be? thanks.
Modified by silverdcteg at 6:20 PM 4/26/2008
Old Apr 26, 2008 | 03:51 PM
wonder squirrel's Avatar
Default Re: idle problem (silverdcteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverdcteg &raquo;</TD></TR><TR><TD CLASS="quote">...the top hole in the t/b has a leak, u can hear the air being sucked. if i cover the hole with my finger the idle goes normal...</TD></TR></TABLE>
Old Apr 26, 2008 | 04:11 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: idle problem (wonder squirrel)
What he ^ is saying is that you have a vacuum leak. That is most certainly the cause of the hunting idle you describe.
My D16Y7 has a vacuum leak but it is a mistery.....
Old Apr 26, 2008 | 05:21 PM
Default Re: idle problem (mcvtec)
so what do i fix lol
Old Apr 26, 2008 | 07:21 PM
Former User's Avatar
Remove and clean the fast idle valve.
Old Apr 26, 2008 | 09:35 PM
Default Re: idle problem (RonJ@HT)
whats fast idle. i changed the iac twice nd did the cold start
Old Apr 26, 2008 | 09:40 PM
Old Apr 26, 2008 | 09:55 PM
i get what your saying but its the top hole we alerady did the cold star and turned it back or w.e
Old Apr 26, 2008 | 10:15 PM
Isn't there a rubber seal(s) between the IACV and throttle body? Could a problem with that rubber seal be the source of your leak.
Old Apr 26, 2008 | 10:23 PM
the iac is on the motor not the t/b but i tried two other iac's nd same problem.
Old Apr 26, 2008 | 10:25 PM
Okay, what does the top hole of the TB serve? If it is the IACV, then look for a leak in the air passage way that connects the two.
Alternatively, is there possibly trapped air or a blockage in the IACV coolant hose that is preventing proper coolant flow through the IACV?
Finally, might you have a problem with the IACV circuit?
Modified by RonJ@HT at 1:39 AM 4/27/2008
Old Apr 26, 2008 | 10:36 PM
goes to the iac but i couldnt have gotten 3 bad iacs. when i cover it the idle evens out like theres a leak there or something
Old Apr 26, 2008 | 10:40 PM
See edited comments in my previous post.
Old Apr 26, 2008 | 11:46 PM
obuhmyuh's Avatar
get the right ecu, its not gonna run the way its supposed to with an auto ecu
Old Apr 27, 2008 | 07:06 AM
Default Re: idle problem (obuhmyuh)
motor was in my friends car nd it had the same problem. nd it did the same thing when i had a gsr ecu
Modified by silverdcteg at 3:11 PM 4/27/2008
Old Apr 27, 2008 | 02:14 PM
still need help
Old Apr 27, 2008 | 04:05 PM
Fatchance187's Avatar
I'm not sure if this will help but, you might want to try bleeding the coolant. That cured my idle bounce.
Old Apr 27, 2008 | 05:19 PM
Default Re: idle problem (Fatchance187)
thanks but no help the motor went in the car nd all new fluids nd everything
Old Apr 29, 2008 | 08:16 PM
help....
Zee.I
Jul 11, 2021 11:36 PM
ryanhauk
May 20, 2009 06:42 PM
Pure Sol
16
Dec 31, 2007 12:06 PM
95civicohyeah
Oct 18, 2007 06:41 AM
LukieLuc
Sep 19, 2007 07:37 PM
