Hypereutectic pistons for H22
Old Apr 26, 2008 | 10:31 AM
Kobane's Avatar
Default Hypereutectic pistons for H22
I live in northern B.C. and im going to be doing a mild all-motor build on my H22. I have had forged pistons in my B16 before and they do not like the cold weather up here, and ive had Hyper-Techs in my Big Block Ford for three years and no problems whatsoever. Im looking for around 240Hp and i was wondering if there was a company that makes this type of alloy piston.
Old Apr 26, 2008 | 11:08 AM
Rocket's Avatar
Default Re: Hypereutectic pistons for H22 (Kobane)
Supertech has nice pistons using a higher silicon and copper enhanced alloy similiar to 4032.
Old Apr 26, 2008 | 12:56 PM
98vtec's Avatar
moderator emeritus
are you staying with FRM cylinder walls?
Old Apr 27, 2008 | 08:28 AM
Kobane's Avatar
Default Re: Hypereutectic pistons for H22 (98vtec)
yep, just gonna bore it out the minimum needed. Then fit the new pistons. Thanks ill check out that company yo.
Old Apr 27, 2008 | 08:30 AM
98vtec's Avatar
moderator emeritus
good luck with that. Hope you figure out how to run a forged piston and not scar the cylinder walls.
Old Apr 27, 2008 | 09:31 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">good luck with that. Hope you figure out how to run a forged piston and not scar the cylinder walls.</TD></TR></TABLE>
ive never understoud the concept that forged pistons cant be run in the FRM cylinders.
Old Apr 27, 2008 | 09:35 AM
98vtec's Avatar
moderator emeritus
Default Re: Hypereutectic pistons for H22 (projectTeG)
its moreso the rings from what I had read in a JE article.
Old Apr 27, 2008 | 09:49 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">its moreso the rings from what I had read in a JE article.
couldnt you use oem rings on forged pistons?
ItzTw
Nov 17, 2004 03:48 PM
H22A_HB
Sep 3, 2004 08:43 PM
b16hybridsol
Mar 24, 2004 05:59 PM
crxrich_kid
Feb 21, 2004 01:25 PM
GSteg
Sep 19, 2002 06:34 PM
