01 ITR vs. CTR valve springs
Old Jul 12, 2002 | 02:34 PM
B16b2b's Avatar
Default 01 ITR vs. CTR valve springs
what, if any, are the differences in the two? if i am not mistaken, i think both engines redline at 8400. is one better than the other? can the ITR springs/retainers perform adequately with the added stress of, let's say TODA B's? (only up to 8400rpm?) and wings rock yo gaebage can motha@#$&!!!!!!
Old Jul 12, 2002 | 02:36 PM
Reid's Avatar
Global Moderator
Default Re: 01 ITR vs. CTR valve springs (1I1I11I)
There are none.
Nope.
They'll be fine up to 8400 rpm.
Old Jul 12, 2002 | 02:37 PM
B16b2b's Avatar
how can i get that stupid *** smiley face changed? ( i'm still a HT virgin)
Old Jul 12, 2002 | 02:40 PM
Reid's Avatar
Global Moderator
Click here
Then change it.
Old Jul 12, 2002 | 02:41 PM
B16b2b's Avatar
Default Re: 01 ITR vs. CTR valve springs (Reid)
thanks for input
Reid's Avatar
Global Moderator
thanks for input
Welcome to HT.
Old Jul 12, 2002 | 05:38 PM
01-1293's Avatar
so many people think the CTR is a civic w/ the type r engine.......its a 1.6 foo's!!!
[Modified by 01-1293, 6:38 PM 7/12/2002]
Old Jul 12, 2002 | 06:00 PM
KF_S2000's Avatar
Default Re: 01 ITR vs. CTR valve springs (01-1293)
Yeppers, B16B.
Old Jul 12, 2002 | 06:12 PM
ITR21's Avatar
Default Re: 01 ITR vs. CTR valve springs (kf_Type-R)
ok first of all there is no difference bettween the two but i think thats already been confirmed. second, theres no way i would use a stock type R valvetrain on Toda B's. My friend has an 01 type R and he tried to use Toda B's with his spoon pistons. It didnt work out to well he started hearing noises from his valves and im pretty sure he actually did damadge to the stock valve train. Any way he ended up haveing to take his engine apart again and take the cams out until he has enough money for the springs and retainers. He then has to take apart his engine AGAIN once he get them to do it right FINALY. I dont know about you but i dont wana be taking my engine apart and putting it together more then once, to install cams. If your gonna do it, do it right.
Old Jul 18, 2002 | 11:43 AM
Reid's Avatar
Global Moderator
Default Re: 01 ITR vs. CTR valve springs (ITR21)
Your friend doesn't know what he's doing.
Stock ITR valvetrain is fine with Spec B's if you don't rev past 8400 rpm.
It's not recommended, but you CAN do it without problems.
The type of pistons he used has nothing to do with his valvetrain problem also.
Old Jul 19, 2002 | 03:31 PM
B16b2b's Avatar
FIRST OFF... no duh on the CTR B16B shiznit!!!
Second Stock ITR valvetrain is fine with Spec B's if you don't rev past 8400 rpm.
QUOTE]...I guess that you really just cannot take advantage of the TODA B's FULLY, only revving to 8400.
i plan on installing a spoon headgasket and CTR pistons before I do the cams...
... i think that a valve/piston clearance problem may arise with this setup. i could be wrong, but i am definetly waiting on the cams until i find out for sure
Old Jul 19, 2002 | 06:18 PM
Reid's Avatar
Global Moderator
There should be no clearance problems with JDM ITR pistons and Spec B's.
99fbpem1
Apr 27, 2009 03:10 PM
moddedmuskegon
Feb 18, 2008 07:19 PM
Rev2 9K
Sep 11, 2005 12:28 PM
Timmayeg
Mar 15, 2002 11:25 AM
ToneyTigre
Nov 1, 2001 12:43 PM
