why wont my Car start?????
Old Apr 25, 2008 | 07:16 PM
jlopez88's Avatar
Default why wont my Car start?????
aight this is the problem i was drivin my car today and it just cut off like the motor shut off when i tried to recrank it the starter sounded like it was stripped out i pulled the stater and checked the starter gear and flywheel and the teeth on both looked fine but the the thing that puzzled me is even if it is my starter why did my car just shut off?? i really dont know my car is a 96 honda civic with a d16y8 and mild motor work done to it such as high compression pistons cam springs and retainers and ecu if anyone could help out it would be greatly appreciated thanks
Old Apr 25, 2008 | 07:48 PM
Former User's Avatar
Default Re: why wont my Car start????? (jlopez88)
Check whether the timing belt snapped. Remove the valve cover and then the upper timing belt cover to inspect.
Old Apr 25, 2008 | 09:40 PM
donvito#1's Avatar
Default Re: why wont my Car start????? (RonJ@HT)
did u have oil in theiror didi a oil light come on it might of seized
Old Apr 25, 2008 | 11:24 PM
v8 integra's Avatar
Default Re: why wont my Car start????? (donvito#1)
iwould check the timing beltttttttttt
Old Apr 26, 2008 | 02:08 AM
x0!'s Avatar
x0!
check your timing belt.
check your battery. maybe the alt is bad and the batteries drained.
Old Apr 26, 2008 | 02:11 AM
REAL TIME's Avatar
Default Re: (x0!)
my car did the same before and it was the alternator. Check on that. Any check engine light codes?
Old Apr 26, 2008 | 03:02 AM
jlopez88's Avatar
OK i will check the timing belt and if its not that i will check the alternator im pretty sure its not the battery because all the lights and everything still come on including the headlights and all that good stuff and it does have oil i appreciate the suggestions keep them comin thanks
[713]
May 14, 2012 03:23 PM
modernvisionscc
Aug 3, 2007 08:56 AM
valve79
Dec 29, 2004 03:20 AM
Timmayeg
17
Apr 29, 2002 07:34 PM
CRzex
Feb 15, 2002 09:55 PM
