Suspension & Brakes Theory, alignment, spring rates....
Do I need to change brake booster after rear disc brake convertion?
Old Apr 24, 2008 | 08:53 PM
djrico724's Avatar
Default Do I need to change brake booster after rear disc brake convertion?
I just did a rear disc brake convertion on my 95 civic.Do I need to change my master and brake booster?IT seems to brake ok.I dont know.What dose every on think.
Old Apr 24, 2008 | 11:04 PM
BlueIntegraBoy's Avatar
Default Re: Do I need to change brake booster after rear disc brake convertion? (djrico724)
No, you don't need to.
Old Apr 25, 2008 | 06:47 AM
gabebauman's Avatar
No.
Did you swap out the proportioning valve though?
Old Apr 25, 2008 | 07:36 AM
hondaboostin's Avatar
no you dont need to. What you should change is the proportioning valve that way under heavy braking in the rain the backs dont lock up, which can send you into a spin. it happen to me once... very scary!!!
Old Apr 25, 2008 | 07:48 AM
Targa250R's Avatar
be professional
Nope, I've never found a need to change the booster when doing brake conversions with OEM parts, unless it's necessary to use a particular master cylinder with a different bolt pattern.
The master cylinder does not need to be upsized for a rear drum-to-disc conversion; it's only necessary when you're swapping on front calipers with larger pistons.
As mentioned, the proportioning valve should be swapped with one from a car with a stock brake system that closest matches your hybrid brake combination to maintain OE proportioning.
Old Apr 25, 2008 | 07:23 PM
djrico724's Avatar
Default Re: Do I need to change brake booster after rear disc brake convertion? (Targa250R)
proportioning valve?Dont know what that is or where it is at.Help!!!!!!!!!!!!!!!!Also when removing the trailer arm I Also removed my stock control arm.Dont know if i shuold replace it with my stock one or if its ok.Let me know.Thanks
Modified by djrico724 at 4:04 PM 4/26/2008
Old Apr 27, 2008 | 12:02 AM
quicksilver1689's Avatar
i ♥ snails
most cars these days will use a combo valve.
Old Apr 28, 2008 | 08:36 PM
immajackuup's Avatar
Default Re: (quicksilver1689)
how hard is it to bleed your whole 4 brake?
Old Jun 3, 2008 | 04:22 PM
dafuzzbudd's Avatar
Default Re: (immajackuup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by immajackuup &raquo;</TD></TR><TR><TD CLASS="quote">how hard is it to bleed your whole 4 brake?</TD></TR></TABLE>
what?
i just bled my brakes for the first time over the weekend with my dad pumping
took 10-15 minutes.
jdm_ek_noob
Apr 3, 2015 08:40 PM
TurboSohc3369
Jun 18, 2007 07:13 AM
devoxtekxhb
Jan 28, 2003 11:39 PM
hmonglonertim
Apr 30, 2002 10:14 AM
