Upper Control Arm - ball joints replaceable?
Old Apr 24, 2008 | 07:38 PM
B18EG6's Avatar
Default Upper Control Arm - ball joints replaceable?
Hello-
Is it possible to replace just the ball joints in the upper control arm? Do they just press in? Are they the same as the lower ball joints?
Thanks!
Old Apr 24, 2008 | 08:47 PM
kirbyman's Avatar
Default Re: Upper Control Arm - ball joints replaceable? (B18EG6)
i guess it could be possible, but it would probably be much less of a hassle and about the same money to have someone do it as it would be to just buy some good aftermarket uca's
Old Apr 24, 2008 | 09:28 PM
EFstyle's Avatar
Default Re: Upper Control Arm - ball joints replaceable? (kirbyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kirbyman &raquo;</TD></TR><TR><TD CLASS="quote">i guess it could be possible, but it would probably be much less of a hassle and about the same money to have someone do it as it would be to just buy some good aftermarket uca's</TD></TR></TABLE>
for sure... your better off gettin some adjustable uca's... much more worth your time and money
Old Apr 25, 2008 | 03:51 AM
B18EG6's Avatar
Default Re: Upper Control Arm - ball joints replaceable? (EFstyle)
Thanks for the advice. I am building the car for a buddy, any recommendations on UCAs? Do you know if any other model civic UCA fit this model? They are all out in the local store.
Old Apr 25, 2008 | 05:40 AM
highroller54's Avatar
88-89 the upper ball joint is welded in, 90-91 is replacable. Thats only if nobody has messed with it.
Old Apr 25, 2008 | 07:04 AM
kirbyman's Avatar
Default Re: Upper Control Arm - ball joints replaceable? (highroller54)
id go with some skunk2 adjustables. that way if you need to fix some camber issues, you can.
Old Apr 25, 2008 | 07:28 AM
~sp33~'s Avatar
EFB055
I had to replace the whole upper control arm, they wouldn't sell just the ball joint itself.
Old Apr 25, 2008 | 08:03 AM
B18EG6's Avatar
thanks for the info - any links on where I can purchase these?
thanks!
Seb
Old Apr 25, 2008 | 08:45 AM
kirbyman's Avatar
http://www.skunk2.com/suspensi...e=FCK
Old Apr 25, 2008 | 09:06 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (kirbyman)
skunk2 are the way to go.. they came out not too long ago and are about the only option out there unless you like cutting up your fenders and wheel well.
Old Apr 25, 2008 | 10:09 AM
_Keith_'s Avatar
That sucks only the pro for the ef... bah
Old Apr 25, 2008 | 06:22 PM
B18EG6's Avatar
Default Re: (_Keith_)
well I got the OEM ball joints out, and I have a press for the new ones...... so I may just press new ball joints in. Certainly cheaper than the s2 counterparts.
now if any of these damn stores locally would carry the upper BJs - by chance, does anyone know if any other years fit? 92-95?
Old Apr 26, 2008 | 12:50 AM
kamakazejack's Avatar
Default Re: (B18EG6)
i can get the joints seperately localy. but im in vic BC canada.. dont know if that helps you at all
Old Jun 6, 2008 | 04:35 AM
gamakichi77's Avatar
Default Re: (kamakazejack)
i'm newbie here..is front upper arms from DB9 can used at EG6?..(SR3)
Old Jun 6, 2008 | 10:34 AM
Tyson's Avatar
you should be able to buy the upper balljoint separately now from local parts stores. i know SPC has a part number for a OEM replacement balljoint (not their adjustables, dont buy those), we replaced them before. i dont have available the part number tho.
but you have to have the 90-91 upper control arms in order to press out the old balljoints. there is a noticable weld around the top of the 88-89's if its welded type.
Old Jun 6, 2008 | 12:17 PM
JOE BD-0's Avatar
Default Re: (Tyson)
Stock replacement parts.....not adjustable.......
SPC part # 67075 = spendy....$40 each, but with a cool red boot......
Beck/Arnley Worldparts(nashville TN)=part # 101-4786....have not tried these, but they are probably cheaper....
Good Luck......
zx12ryder
Oct 9, 2008 02:24 PM
Gsir8
Jun 21, 2007 06:48 AM
DaChoZn1
Sep 18, 2005 03:34 PM
huyvu90
Oct 28, 2004 06:33 AM
DaChoZn1
Jul 30, 2004 02:23 PM
