When does your car hit peak boost?
Old Jul 12, 2002 | 12:10 PM
RATEDR's Avatar
Default When does your car hit peak boost?
[Modified by RATEDR, 12:21 AM 9/10/2002]
Old Jul 12, 2002 | 01:41 PM
HXMan's Avatar
Default Re: When does your car hit peak boost? (RATEDR)
Mine probably hits around 4000 with a t3/to4b on a b16a2. No cat, and a Tanabe RM...I need 3"!!!
Old Jul 12, 2002 | 01:43 PM
Trigun's Avatar
Default Re: When does your car hit peak boost? (HXMan)
mine hits full boost around 3.5k and then it really hits you at about 6k.
Old Jul 12, 2002 | 01:47 PM
CovertFI's Avatar
Default Re: When does your car hit peak boost? (Trigun)
i hit full at 4k but really pulls at 5k
Old Jul 12, 2002 | 02:03 PM
RATEDR's Avatar
Default Re: When does your car hit peak boost? (CovertFI)
[Modified by RATEDR, 12:22 AM 9/10/2002]
Old Jul 12, 2002 | 02:44 PM
311's Avatar
311
mine hits full around 4000-btw TJ, the front mount looks tight y0!
Old Jul 12, 2002 | 05:34 PM
Damon B.'s Avatar
Default Re: When does your car hit peak boost? (311)
now when you guys are saying you hit full boost in a certain rpm, which gear would this be in?
Old Jul 12, 2002 | 05:39 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: When does your car hit peak boost? (CleanSi)
Try this out: go about 30miles/hr and put it in 5th. Give it full throttle and let the boost climb slowly and once it reaches full boost then look at your tach to see where you reach full boost.
art
Old Jul 12, 2002 | 10:43 PM
Damon B.'s Avatar
Default Re: When does your car hit peak boost? (Arturbo)
is that like the "official" way to check?
Old Jul 12, 2002 | 11:07 PM
*Boostwerks*'s Avatar
art
And suddenly......"Oh ****! I'm going 120 and havn't even hit full boost yet!"
Old Jul 12, 2002 | 11:17 PM
falcongsr's Avatar
What is this crap?
is your wastegate opening up early? are you running a boost controller?
Old Jul 12, 2002 | 11:36 PM
Vsm Hatch's Avatar
Default Re: When does your car hit peak boost? (Bryson)
ROLMAO!!
deng mah bro just finsihed his turbo setup and is only boosting 4psi on a GSR until he finsishes all da little stuff on his setup... He took me for a ride today... Barely Boosted... all i could say was WOW!!
I can't even drive yet and i got boost bug!!
Old Jul 13, 2002 | 06:47 AM
EVIL CETANE's Avatar
I hit full boost at 1000 rpm = 10psi
Old Jul 13, 2002 | 07:01 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: When does your car hit peak boost? (cetane)
LOL, with the JRSC.
Old Jul 13, 2002 | 10:59 AM
quikrpm'z's Avatar
art
wouldnt that put a lot of stress on the engine?
Old Jul 13, 2002 | 02:02 PM
shadowdawn's Avatar
Default Re: When does your car hit peak boost? (quikrpm'z)
I hit full boost at around 4000 and change rpms, wastegate starts dumping hard at 5000rpm, and the car pulls from 3500-redline.
I have a t3/t04e .53 a/r compressor housing, and STOCK EXHAUST!!! no bc or anything like that, just my dependable tial with .45 bar spring in her chrome sexy ***.
Old Jul 13, 2002 | 02:41 PM
Speed PHreak's Avatar
Default Re: When does your car hit peak boost? (shadowdawn)
Full boost by 4000 rpm @ 10 PSI
B18A
T3/T04E
3" exhaust
Old Jul 13, 2002 | 03:34 PM
DC2R714's Avatar
Default Re: When does your car hit peak boost? (Speed PHreak)
I hit full boost at 3500-4000. 2.5" DP. 2.25 exhaust. t3/t4 .50a/r
Mr.DC2TurBo
Apr 24, 2004 02:19 PM
HotRodTeg
Oct 4, 2003 11:19 PM
ezark
Feb 2, 2002 12:37 PM
