why is my check engine light go on when im boosting?
Old Apr 24, 2008 | 11:36 AM
zachsbat1's Avatar
Default why is my check engine light go on when im boosting?
ok i have a chipped p06 in it 270cc injectors,and when i start to boost my check engine light goes on and then the car bogs down...map sensor since i havent the oe?
Old Apr 24, 2008 | 11:48 AM
zachsbat1's Avatar
Default Re: why is my check engine light go on when im boosting? (zachsbat1)
its on a 93 civic ex with a d16z6 dx tranny,only has 85k
Old Apr 24, 2008 | 12:36 PM
sp00led's Avatar
boost cut?
Old Apr 24, 2008 | 12:43 PM
zachsbat1's Avatar
Default Re: why is my check engine light go on when im boosting? (sp00led)
kinda but when the check engine light comes on it like slows down and stuff...
quicksilver1689's Avatar
i ♥ snails
how much boost are you running? when u say chipped p06, what program are you using for tuning? give us some details man.
Old Apr 24, 2008 | 12:48 PM
Supacharge's Avatar
Default Re: (quicksilver1689)
stock map sensor?
Old Apr 24, 2008 | 12:52 PM
zachsbat1's Avatar
Default Re: (Supacharge)
stcok map sensor i think thats what it is and it has a xs chip in it..
zachsbat1's Avatar
8 psi....has a new head gasket and the internals were cleaned when doing so
Old Apr 24, 2008 | 01:08 PM
HRTuning's Avatar
Default Re: (zachsbat1)
"XS" chips aren't for boost, so ya, when you boost you'll throw a code for it. Get it tuned properly, or at least a proper basemap setup to allow boost.
Old Apr 24, 2008 | 01:20 PM
zachsbat1's Avatar
Default Re: (HRTuning)
so should i just sell the p06 and the chips?or what?do i need another ecu
Old Apr 24, 2008 | 01:28 PM
HRTuning's Avatar
You need a new chip setup properly. And perhaps some bigger injectors.
Xenocron.com
J-K-Tuning.com
Phearable.net
Search...
Old Apr 24, 2008 | 01:29 PM
zachsbat1's Avatar
ok so for now put the the original back in?
Old Apr 24, 2008 | 01:30 PM
HRTuning's Avatar
No, that'll throw a code too....... it's not setup for boost. Go search, there's plenty of information on this.
Old Apr 24, 2008 | 01:31 PM
alexsracing's Avatar
you need a chip with the boost portion of the map filled in
Old Apr 24, 2008 | 01:53 PM
zachsbat1's Avatar
Default Re: (alexsracing)
ok so i can use this ecu?and just not that chip?
Old Apr 24, 2008 | 05:04 PM
HRTuning's Avatar
Right
Shoalin R
May 21, 2010 01:42 PM
GSE980
Jan 24, 2010 04:50 PM
Kavman
Apr 19, 2009 11:11 PM
XBoostedAccordX
Aug 17, 2004 10:47 PM
wambus
Aug 12, 2003 07:38 AM
