Boosting b16a Wat Valvetrain
IM boosting a b16a im buying new cams springs retainters and valves
I want to go with skunk2 but i dont know Wich cam gears to buy. I know pro series stage 2 is rated for like 11.5.1 compression pistons. But i dont know wich should be used in a boost build? I was thinking of just goin with brian crower Stage 2 Boost cams and fil brian crower valve train Tell me wat you think.
I think you're wasting your money using that block (since you're spending so much elsewhere), but you must have a reason. Look around the archives (search button, select archives) and you'll find examples. The first thing you should do is ask "what do i want for power?"
For sub-300whp, don't touch anything (besides seals/guides).
For 300-400whp, ITR cams.
>400whp, ITR or bigger cams, depending on the turbo.
FYI OEM b16 cams can carry you to 400whp with the right turbo kit.
JustEFit
19
Jun 24, 2013 03:34 PM
fracas
Dec 29, 2010 03:24 PM
