Battery Issues. (dead battery after it rains only...fine otherwise ) HELP!
Old Apr 24, 2008 | 08:39 AM
ZappasOne's Avatar
Default Battery Issues. (dead battery after it rains only...fine otherwise ) HELP!
Car is a 97 Ex Coupe w/ gsr swap. p72 ecu
Brand new battery (thought old one was bad, it wasnt ).
alternator tested fine.
starter tested fine.
there are no obvious shorts or anything like that.....nothing stays on..ect ect.
Im lost as to why rain could cause this, thus my post for help.......
any information would be appreciated! thanks.
Old Apr 24, 2008 | 09:06 AM
SamSpade's Avatar
Default Re: Battery Issues. (dead battery after it rains only...fine otherwise ) HELP! (ZappasOne)
Unfortunately this is not normal as i'm sure you know.
If you have a good battery, a good alternator, and no short......your problem should be easy enough to find and fix. Offer more details concerning the issue please.
-How many times has this happened?
-When you cannot start the car, is it not even cranking?
-Has it been hot/humid where you're located (when this has happened)?
-Has the battery been relocated?
How did you check the alternator and starter to rule them out? also, how do you know there is no short in the car (can you explain the test/s you did to rule this out)?
Things to check,
-Make sure both battery terminals are tight and clean
-Follow the ground wire from the battery and make sure it's secure on both ends
(if you've already checked this stuff, good job)
Cheers
Old Apr 24, 2008 | 09:38 AM
ZappasOne's Avatar
Default Re: Battery Issues. (SamSpade)
- Not sure on specific times, but everytime it rains...
- The car doesnt crank at all, completely dead.
- Yes, not neccesarily "hot", but i'd say 80's and humid after it rains.
- The battery is in its orginial location.
- Volt meter for the starter and alternator to test draw from battery. (I havent gone into much more with the volt meter, because of only happening when it rains. but visual inspection i see no obvious shorts.
- Terminals are tite and clean.
- The battery ground wire is secure.
Old Apr 24, 2008 | 09:40 AM
ZappasOne's Avatar
Also...the battery starts up with a jump but is weak.
Old Apr 24, 2008 | 09:44 AM
Taimaishui14's Avatar
Default Re: (ZappasOne)
Do you have a system in your car? Anything else you've wired up yourself?
I had this same problem in my car, it was due to my system getting wet. Ive got a crack in the rear quarter from an accident and water leaks in. It then splashed around and shorted everything out causing my battery to die. Took it out for a week, let everything dry out, then put it back in, rerouted my power cables and put my ground up higher, and it works fine now, even when it rains.
Old Apr 24, 2008 | 09:53 AM
ZappasOne's Avatar
Default Re: (Taimaishui14)
Nope, no system nothing wired shady or getting wet.....
Old Apr 24, 2008 | 10:58 AM
obuhmyuh's Avatar
i had this problem: https://honda-tech.com/zerothread?id=2191482
turned out to be a short.
Old Apr 24, 2008 | 11:05 AM
ZappasOne's Avatar
Default Re: Battery Issues. (obuhmyuh)
appreciate it.
Old Apr 24, 2008 | 11:08 AM
obuhmyuh's Avatar
Default Re: Battery Issues. (ZappasOne)
if it helps at all with that thread, my engine woul crank but not turn.
GL
Johnoolo
Sep 16, 2013 05:15 AM
Touek
Oct 21, 2011 03:20 AM
manyakiexpi
Nov 14, 2006 10:20 AM
sky88
Jul 20, 2004 08:57 AM
Hung
Apr 20, 2002 02:58 PM
