Suspension & Brakes Theory, alignment, spring rates....
suspension problem
Old Apr 23, 2008 | 08:11 PM
quicksilver1689's Avatar
i ♥ snails
Default suspension problem
hey guys, been along time since i posted in this section here goes, i have tein s-tech's on some tokico illuminas, basically, like twice this month when i hit a pretty mean pot hole the shock shaft somehow pushed through the bushing in the top hat and i have my shock shaft hitting my hood when i drive. Its done this twice now, i usually just take the 5 min and remove the shock and redo the bushings and put it back together but its starting to become a real PITA. Should i buy new bushings? is it possible that i had stretched them? anybody have any insight or expierience this problem before?
Old Apr 23, 2008 | 08:55 PM
BinMop's Avatar
Default Re: suspension problem (quicksilver1689)
i think u forgot to put the washer underneath the top hat
Old Apr 24, 2008 | 08:19 AM
gabebauman's Avatar
Default Re: suspension problem (BinMop)
Old Apr 24, 2008 | 12:05 PM
i ♥ snails
hmmm all i remeber is putting this little metal sleeve over the shockshaft putting the first bushing on then this larger sleeve top hat bushing then the washer and nut on the top, i guess my dumbass forgot something hmmmm.
Old Apr 24, 2008 | 12:13 PM
i ♥ snails
nope, from my manual it says that i have all the required pieces, maybe i overtorqued the nut on top and it compressed the washer too much on the mouting rubber causing the hole to expand or something? what do you guys think? just get a new set?
Old Apr 27, 2008 | 12:00 AM
i ♥ snails
bump
specbb6
Suspension & Brakes
19
Dec 19, 2012 08:53 PM
erebunicrx
10
Mar 12, 2005 06:45 PM
jerbear!
Suspension & Brakes
Feb 9, 2005 04:10 AM
J-g-D-s-M-r
Oct 8, 2002 06:46 PM
DragII
Jun 27, 2001 04:53 AM
