overheating......sometimes
few days ago i went to tune the new e85 fuel. did 6-7[3rd AND 4th gear] pulls with about 10min between each one and the temp never went over 198*. yesterday i did a quick 3rd gear pull an noticed my ECT were climbing slowly after. it went up as high as 220*. i kept driving and it fell to 200* after a few min [no more then 4,5min]. both days temp was relatively the same at around 50-60*
this is car is my DD for now and the temp never gets over 194-196* driving around and getting on it here and there. only time the overflow tank gets full was few weeks ago when i was at the track and yesterday after that little run.
there is some headgasket looking stuff in the overflow[no oil/coolant mixing anywhere] but im thinking it could be from last year when my old motor blew one.
ideas ?
btw, bone stock b16a; holset he351cw @12psi; maximum of 16.75* of timing.....
ideas ?
sounds dumb, but check the coolant. could be low if there's a leak somewhere. probably should clean out that reservoir also. do you know if your fan is working?
djoye
Apr 9, 2008 06:51 PM
