Turbo on angle can cause bearings to fail??
Old Apr 23, 2008 | 05:46 PM
L_J_Scheepers's Avatar
Default Turbo on angle can cause bearings to fail??
if you draw a line through the centre of the bearings in the turbo, does it matter if this line is not horizontal
i have had a few people say to me that if the turbos central axis is not orizontal it will destroy the bearing quickly - we were talking more specifically about journal bearings, they said that the oil would pond and the lower end and the higher bearing would sieze
im thinking BS, but anyone heard anymore about this, many of you guys build manifolds, where the turbo is on an angle???
Old Apr 23, 2008 | 07:04 PM
RAK's Avatar
RAK
Default Re: Turbo on angle can cause bearings to fail?? (L_J_Scheepers)
The turbo is fed by pressurized oil, I don't think it would matter, as long as the oil can drain back to the engine properly.
Old Apr 23, 2008 | 10:36 PM
Vince64's Avatar
Default Re: Turbo on angle can cause bearings to fail?? (RAK)
i'm pretty sure the center section can take a little bit of an angle and still work fine
Modified by Vince64 at 1:27 AM 4/24/2008
Old Apr 23, 2008 | 11:29 PM
jzz30's Avatar
the fullrace manifold for the k20 tilts the turbo up at an angle. i dont see a problem with it
Old Apr 24, 2008 | 08:20 AM
locash's Avatar
It shouldn't cause turbo failure, but the thing will dump oil into the exhaust housing and smoke like hell if left at idle for any length of time..
Old Apr 25, 2008 | 06:48 AM
newby_j's Avatar
Needs More Cowbell
Default Re: Turbo on angle can cause bearings to fail?? (locash)
It needs to be level. That is what has been recommended by all of the manufacturers that i have seen.
Old Apr 25, 2008 | 07:07 AM
EdsGTI's Avatar
Default Re: Turbo on angle can cause bearings to fail?? (newby_j)
I believe I remember hearing/reading they recommend no more than 15 degrees from level in either direction.
Old Apr 25, 2008 | 07:42 AM
welfarepc's Avatar
every factory setup ive seen the drain goes straight down... no tilting
Old Apr 25, 2008 | 09:22 AM
Garage 808 Hatch's Avatar
Default Re: (welfarepc)
they will work at an angle, but im pretty sure its hard on the thrust bearing.
Old Apr 25, 2008 | 04:03 PM
HiProfile's Avatar
Default Re: (Garage 808 Hatch)
I've seen recommendations calling for no more than 30*, and I had around 15* on my last car. Granted it only ran 2000 miles, it was a used turbo, and was no worse for wear afterwards. I did have a .060" restrictor on it though. The only problems angle could cause is a slight amount of sideload, meaning wearing the thrust bearing a tad more. But with the comrpessor side up, it would probably balance out any forces from the turbine pushing and comp pulling from the chra due to airflow.
BTW I wouldn't look at factory setups to be gospel. If we took a hint from Volvo, we'd have tiny exhausts, and probably a GT17-size turbo on our 1.8L's... Of course they put them straight, the design it into the engine & bay to be optimized for longevity. Most motors/setups here won't see the 100K they expect from factory turbos (yet rarely get anyways).
Old Apr 29, 2008 | 12:46 PM
Boosted_B_Series's Avatar
subscribed... I have built two setups with angles on the turbo..
Heres mine
Old May 1, 2008 | 12:58 PM
PA MATT's Avatar
Default Re: (Boosted_B_Series)
i'm almost positive they don't mean an angled turbo like yours which is side to side. They are talking about turbo's that position the exhaust housing to lean back or oil drains that don't drain because they are clocked.
Old May 2, 2008 | 12:00 PM
my turbo is clocked at a wild angle, look at it.. I'm not talking about side to side, look were the oil inlet is ..
Old May 2, 2008 | 12:13 PM
thats fine. they are talking about shaft being at an angle.
Old May 2, 2008 | 12:16 PM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L_J_Scheepers &raquo;</TD></TR><TR><TD CLASS="quote">if you draw a line through the centre of the bearings in the turbo, does it matter if this line is not horizontal
Uh yeah, if you have the bearing housing horizontal you will destroy the bearings. Vertical however...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted_B_Series &raquo;</TD></TR><TR><TD CLASS="quote">subscribed... I have built two setups with angles on the turbo..
Heres mine
You know... I'm looking at that picture and I just can't figure out why you wouldn't just have the bearing section completely vertical...
Old May 2, 2008 | 12:17 PM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch &raquo;</TD></TR><TR><TD CLASS="quote">thats fine. they are talking about shaft being at an angle. </TD></TR></TABLE>
Ohhhhh, I get it now.
Well, as they say, gravity is a bitch.
Old May 2, 2008 | 01:24 PM
HiProfile's Avatar
Default Re: (SovXietday)
I think the OP was talking about the shaft axis [angle], not the axis between oil inlet/outlet. I know for certain that you want 15* from vertical (either way) at the most for the oil inlet/outlet axis. That looks like 40* from vertical on that topmount.
Old May 2, 2008 | 02:05 PM
SovXietday's Avatar
Default Re: (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">I think the OP was talking about the shaft axis [angle], not the axis between oil inlet/outlet. I know for certain that you want 15* from vertical (either way) at the most for the oil inlet/outlet axis. That looks like 40* from vertical on that topmount.</TD></TR></TABLE>
Yeah, I realized that right after I posted what I did, hence the double post.
Old May 2, 2008 | 06:12 PM
Alfa Turbo's Avatar
Come on guys... how is a 45* angle any different than 1g force in any direction?
The F1 buggies put a lot more than that on them...
Point is, NO, it does not matter.
b00stedOne
Jan 1, 2011 10:31 PM
blwn95civic
Oct 12, 2008 02:41 AM
o'malley_808
Sep 2, 2005 06:11 AM
lvf03
Feb 22, 2004 08:11 PM
JChops
Nov 12, 2003 11:40 AM
