car wont idle stalls at every stop WEIRD
Old Apr 23, 2008 | 05:31 PM
martyball619's Avatar
Default car wont idle stalls at every stop WEIRD
ok so this morning i turned on my RSX and surprisingly it idled very low. around 300-400 rpms. then i drove it and it felt a little hesitant. after that, it started to stall at every dead stop. the only way i can go is if i dont make a full stop because my car wouldnt idle. no check engine light and everything is hooked up properly. then at one point i got mad. i floored it on 1st gear and tada... problem fixed. no more stalling.. anybody got any idea?
Old Apr 23, 2008 | 07:27 PM
typesnick's Avatar
Default Re: car wont idle stalls at every stop WEIRD (martyball619)
spark plugs.......
Old Apr 24, 2008 | 02:54 AM
WyldRice's Avatar
maybe this will help?
i had similar effects, but also had high idle at times- lurching when trying to creep in first gear.
i didn't have a check engine light at first, but mine was throwing the codes after a week of driving like that...
it was my rotory control valve- as the dealer calls it (aka. Idle Control Valve- ICV... AKA- Idle Air Control Valve- IACV)
try cleaning it first- there are DIY's on it somewhere on the net.
Old Apr 26, 2008 | 11:10 PM
integra_s's Avatar
It could also be your Tps. It could be bad
Old Apr 27, 2008 | 11:58 AM
thetunersource's Avatar
Default Re: (integra_s)
bad TPS sensors usually throw a check engine light. its probably still its acceptable range of voltage. Try your plugs and clean out ur ICV. Then reset ur ECU
frostykue
Mar 28, 2013 08:29 PM
matt_in_sd
Dec 14, 2006 11:58 AM
kawickstrom
17
Jun 12, 2006 03:15 PM
Mr si99
May 5, 2005 08:31 PM
PaChiLa Leader
Jul 1, 2002 02:32 PM
