check engine light ON....
Old Apr 23, 2008 | 04:42 PM
civicx's Avatar
Default check engine light ON....
Hi everyone,
My car were running fine when I drive to work. However, when I'm coming back from work, running fine and when I got half way home, my rpm can't go pass 5000 rpm and when I push the gas pedal seems like no gas. I shift to lower gear and went pass 5000 rpm, then I shift back to high gear again and did pass 5000 rpm.
Now, I can't even go pass 3000 rpm when the check engine light ON and the rpm jump up and down. After that, its stay above 2000 rpm won't come to normal even its hot. I haven't check anything yet but that's the problem now. I can't even go pass 3000 rpm and idle's not normal. Also hard to start, sometimes won't even start and if i keep on trying to start, its getting weaker. My car is obd2 dohc vtec.
PM if anyone know what's wrong.
Old Apr 23, 2008 | 05:29 PM
superfast666's Avatar
Default Re: check engine light ON.... (civicx)
if there is a check engine light you need to pull the code
Old Apr 23, 2008 | 05:38 PM
civicx's Avatar
Default Re: check engine light ON.... (superfast666)
i can't see the inside code on the ecu, unlike my pr3 that show the code
Old Apr 23, 2008 | 05:41 PM
killmeamerika's Avatar
search. https://honda-tech.com/zerothread/1901557
Old Apr 24, 2008 | 02:34 PM
civicx's Avatar
Default Re: check engine light ON.... (killmeamerika)
thanks for the help..i'll try.
Old Apr 24, 2008 | 02:45 PM
k20superchargedtuboitbs's Avatar
let us know what code it throws
MrLeon77
Dec 25, 2015 01:48 PM
blink_977
May 21, 2009 12:45 AM
dirtycolombian
Jun 5, 2007 06:21 AM
MinimalXistance
12
Apr 15, 2006 12:24 AM
KOVENANT
Oct 4, 2004 01:09 AM
