Please READ! ive searched!! trouble starting/manually warming up car!!!
the car: 92 civic hatch vx
set up: ls-vtec
the problem: well after letting it sit for the night ill have to manually warm it up. what i mean by that is if i start it up regularly ill have to hold the gas around 1700 rpm. if i let it go the car will die this only happens when i first start it up for the day after that it starts up like a champ. is it a wiring problem or what? please someone help me!!!!
ive searched but no one has had a problem like mine so i want to know if anyone out there can help me out!
set up: ls-vtec
try running some injector cleaner through it. the injectors might be sticking. do you hear your fuel pump prime?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a3delsol »</TD></TR><TR><TD CLASS="quote">try running some injector cleaner through it. the injectors might be sticking. do you hear your fuel pump prime?</TD></TR></TABLE>
ill try that and yea i do hear it prime i always start my engine after the check engine light turns off
simplegreenmachine
Dec 24, 2007 04:00 PM
