JUNKYARD BUILD ON A SOHC..........CHECK IT OUT.
Old Apr 22, 2008 | 09:47 PM
ivan93egreppin210's Avatar
Default JUNKYARD BUILD ON A SOHC..........CHECK IT OUT.
KEEP IN MIND MOST THIS STUFF ASIDE FROM THE TRANNY IS FREE.
my friend has a shop with like a million old swap parts and were building up my other friends d15b7 with old parts lying around. he has no funds so were doing all this for him for free. what i have so far is....
1. d16a6 cam (what cam gear and how do i identify the a6 cam)
2. z6 tranny
3. y8 intake mani (B20Z2 tb?)
4. what ecu is best?
we have all these parts lying around. any stock pistons that fit this block that will bump his compression? anything else we should look into. he is saving for a b series that he plans to build so we arent realy spending any money on this setup. were just trying to give his old beater a little life before it gets pulled aside and forgoten.
Old Apr 23, 2008 | 03:26 PM
Default Re: JUNKYARD BUILD ON A SOHC..........CHECK IT OUT. (ivan93egreppin210)
please help. this might help alot of guys out there that are stuck with the d15b7 for lack of cash. not everyone that owns a honda can afford swaps and turbo.
Old Apr 23, 2008 | 03:38 PM
CivicEK321's Avatar
Dude, get some pics so we can see it. Please.
Old Apr 23, 2008 | 03:51 PM
z6hatchboy's Avatar
Out of what you have, the b7 pistons will already make the comp higher than if you used z6 ones. I dont konw what a a6 cam will do but i know if you could find a z6 head then it would see the most gain there i think, and with the z6 trans will be that much better.
Old Apr 23, 2008 | 03:56 PM
Default Re: JUNKYARD BUILD ON A SOHC..........CHECK IT OUT. (CivicEK321)
if you mean pics of the d16a6 cam, i dont have any. he has like 7 cams in a box and he swares one is the d16a6 cam. i looked all over the net but i cant find a pic of a stock a6 cam compared to b7 and so on. PRETTY MUCH WERE TRYING TO MAKE CHICKEN SOUP OUT OF CHICK ****.
Old Apr 23, 2008 | 04:09 PM
Default Re: JUNKYARD BUILD ON A SOHC..........CHECK IT OUT. (z6hatchboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy &raquo;</TD></TR><TR><TD CLASS="quote">Out of what you have, the b7 pistons will already make the comp higher than if you used z6 ones. I dont konw what a a6 cam will do but i know if you could find a z6 head then it would see the most gain there i think, and with the z6 trans will be that much better.</TD></TR></TABLE>true but my boy with the shop doesnt have a good z6 head. MISTA BONE WHERE ARE YOU. mista bone made 140 whp using an a6 cam in a b7 wth i/h/e and tuning. he is the reason we are even trying this monkey chit.lol
Old Apr 23, 2008 | 05:53 PM
b16a3delsol's Avatar
i may be wrong but 140 i feel is pushing the envelope a little but who knows
Old Apr 23, 2008 | 08:40 PM
EKstacy's Avatar
Default Re: JUNKYARD BUILD ON A SOHC..........CHECK IT OUT. (b16a3delsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a3delsol &raquo;</TD></TR><TR><TD CLASS="quote">i may be wrong but 140 i feel is pushing the envelope a little but who knows
x2...but id love to see proof, cause that sounds pretty cool.
Old Apr 23, 2008 | 10:14 PM
projekt-sol's Avatar
Default Re: JUNKYARD BUILD ON A SOHC..........CHECK IT OUT. (EKstacy)
be careful with the B7. i just pulled mine out due to throwen rod.. put a hole in the side of the block.. but i had a Z6 head. b7 cam gear on it. I/H/E and z6 tranny she was a fun lil toy.. till that damn water puddle hydrolocked the motor and snapped a rod. PICS R A MUST! there are some out here who just like random builds.. and i agree 100% i got all my parts from blowen motors that were going to be scrapped.
Old Apr 23, 2008 | 10:16 PM
DCSportEJ1Civic's Avatar
Default Re: JUNKYARD BUILD ON A SOHC..........CHECK IT OUT. (projekt-sol)
shift forks in the 6z trannys are aluminum and very weak. i would do a y8 tranny myself.
spork motorsports
Nov 20, 2006 08:07 AM
KMk51188
20
Aug 7, 2006 05:12 PM
FalkenSiR
Dec 25, 2004 02:59 PM
BLiTZ BLuE CiViC
Mar 20, 2004 05:00 PM
