Can you put gsr i/m on ls?
Old Apr 22, 2008 | 04:05 PM
mike03,95civic's Avatar
Default Can you put gsr i/m on ls?
So i am planing on buying an edelbrock turbo kit but it only comes for the gsr and i have a ls motor. i know i'll have to get it tuned because the piggyback is for the gsr but i want to know would the intake manifold for the gsr would fit on my motor?
Also any body know if anything else would have to be changed or modified to make it work?
Old Apr 22, 2008 | 04:07 PM
z6hatchboy's Avatar
Default Re: Can you put gsr i/m on ls? (mike03,95civic)
Im thinking it is a straight bolt on, but dont hold me to it.
*edit*, thanks eran for the reply, im deff. a d-series guy haha.
Eran's Avatar
HT White Ops
First of all -- No, you can't. The bolt pattern is different.
Second of all -- Why would you want the GSR manifold? All the hassle with the odd throttle body placement and the dual butterflies?
Old Apr 22, 2008 | 04:10 PM
Phoenix_ITR's Avatar
Default Re: (Eran)
not to mention the fact that it would most likely be cheaper to just remake or modify the cold-side charge pipe. that should be the only component of the kit that won't fit.
Old Apr 22, 2008 | 04:14 PM
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">First of all -- No, you can't. The bolt pattern is different.
Second of all -- Why would you want the GSR manifold? All the hassle with the odd throttle body placement and the dual butterflies?</TD></TR></TABLE>
I just would rather not spend another $300 on a ls i/m
so if i put on an ls manifold would the piping need to be modified?
Old Apr 22, 2008 | 04:17 PM
Default Re: (mike03,95civic)
see my comment above.
yes, it would most likely need to be modified as the GSR throttlebody placement differs from the LS.
Old Apr 22, 2008 | 04:19 PM
Default Re: (Phoenix_ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phoenix_ITR &raquo;</TD></TR><TR><TD CLASS="quote">see my comment above.
yes, it would most likely need to be modified as the GSR throttlebody placement differs from the LS.</TD></TR></TABLE>
oh yea my bad. thanks for the info guys
Old Apr 22, 2008 | 04:21 PM
the ls i/m looks longer. if i have to modify it to make it longer how would i do that?
Old Apr 22, 2008 | 04:26 PM
if you're asking how to make the charge pipe longer, you'd just cut it, add material, and reweld it. no big deal at all.
Old Apr 22, 2008 | 04:28 PM
yeah i wasn't sure if the material the pipe was made of was weldable
Old Apr 22, 2008 | 04:30 PM
it's most likely just aluminum -- anyone with a TIG welder can take care of it for you.
Old Apr 22, 2008 | 04:31 PM
ok good to know
Ge-money
Feb 10, 2007 01:51 PM
stickyfingers
May 4, 2005 07:32 PM
Metzler
Nov 22, 2004 07:16 PM
B18Redline
Jul 24, 2003 02:27 PM
LsBoy
Mar 18, 2003 02:10 PM
