Thermal Expansion valve
Old Apr 22, 2008 | 03:27 PM
motorD16Y7's Avatar
Default Thermal Expansion valve
First of all, I have no ideal where is this post belong to.
I recently changed my Thermal Expansion Valve (TXV) from AutoZone and did all the pipe cleaning, exchanged the condenser and evaporator. Unfortunately, my A/C still not cold. I am guessing is my TXV not working right.
A friend of my said that I can buy the ARI certified TXV from the store which I went to checked and has been closed down.
Therefore I am asking if anyone know any website that sells ARI certified TXV.
If this is not the right place to be. Please move me to the right forum.
Thanks.
Old Apr 23, 2008 | 10:39 AM
motorD16Y7's Avatar
Default Re: Thermal Expansion valve (motorD16Y7)
Anyone
Old Apr 23, 2008 | 01:08 PM
SiTR's Avatar
bought mine from orielys and havent finished putting it on yet should be blowing cold by tongiht. Ill let you know if the one i got from orielys works good
Old Apr 23, 2008 | 02:33 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (SiTR)
is your system full of refrigerant??
Check that first.
Does the clutch engage??
Old Apr 23, 2008 | 08:49 PM
HoOridin's Avatar
first, do a feel test.... feel the low side lines, if they get freezing cold, u probly have a blend door, etc problem...
what are ur guage readings? too high? too low?
lets diagnois before you start throwing parts at the car...
Old Apr 23, 2008 | 09:38 PM
SiTR's Avatar
well just got all my parts on and did a vacum on it and the dam belt they gave me was the wrong one. So know i have to wait till tomorrow to get the right one then charge it.
Old Apr 24, 2008 | 09:25 AM
motorD16Y7's Avatar
Default Re: (Evs-One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One &raquo;</TD></TR><TR><TD CLASS="quote">is your system full of refrigerant??
Check that first.
Does the clutch engage??</TD></TR></TABLE>
The system is fully charged and the compress does work good.
Old Apr 24, 2008 | 09:33 AM
motorD16Y7's Avatar
Default Re: (HoOridin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoOridin &raquo;</TD></TR><TR><TD CLASS="quote">first, do a feel test.... feel the low side lines, if they get freezing cold, u probly have a blend door, etc problem...
The line does feel cold. I have disconnected the cooling line going indoor. I read from both the low and high side and they are within the range when the car is in idle condition but once I gas up to around 3000rpm, the high side go up to around 300psi and low side drops to around 20psi. That is why I am thinking the TXV is not working right.
I only feel cold when surrounding is not too hot but once it is too hot I don't feel as cold anymore. I have turn on the A/C for an hour but still not cold.
lhurba
Nov 24, 2007 08:51 PM
phoenix_iii
Mar 28, 2007 10:27 AM
tsjeff
Aug 30, 2003 06:42 AM
TheSwift1
Aug 24, 2003 04:29 PM
