Trouble after new distributor?
Old Apr 22, 2008 | 11:58 AM
coocoobird79's Avatar
Default Trouble after new distributor?
Hey everyone
I have a 90 Honda civic LX that started squealing from the bearing going out (red dust everywhere) so i got a new distributor from autozone. Now i forgot to see what way the rotor was facing before i changed it so i could put it back on the same way. So the first try it wouldnt start so i knew what it was. I took the distributor back off and turned the rotor 180 degrees and it started right up but now whats happening is its running rough and spark knocking. I cant find my timing light atm so i dont know exactly what its set at though no matter where i move the distributor it still runs rough. The idle basically is jumping a up and down really quick, not really like a surge though. But anyways i test drove it like that and what happens is that if i gun it to like 6k rpm it will turn the check engine light on then automatically wont let me go over 3.5k rpm in all gears. Im assuming this is a limp home mode? The ecu code that i get is 4 quick blinks which is the crankshaft timing sensor i think?. Did i miss an adjustment somewhere or did i maybe get a bad distributor?
Modified by coocoobird79 at 1:11 PM 4/22/2008
Old Apr 22, 2008 | 02:48 PM
Crx Jimmy's Avatar
Default Re: Trouble after new distributor? (coocoobird79)
you did something wrong if you got the dizzy on 180 out. the keyed shaft is offset so it can only be put in one way, I have seen one tried to be jammed on the wrong way and bolted down, you dont want to know what happened
Old Apr 22, 2008 | 07:24 PM
welfarepc's Avatar
perhaps you jumped a tooth when your dizzy siezed up
check the firing order too...
dizzy 3 2 4 1 timing belt
Kaminsky
14
Aug 7, 2015 03:03 PM
cyclonedr
Oct 29, 2010 04:05 PM
92EG8
18
Jan 9, 2007 11:48 AM
MAXFLOW2
Feb 23, 2005 11:50 PM
90_crx_si
Mar 23, 2004 03:58 PM
