How do you lean out a D-Series engine??
Old Apr 22, 2008 | 09:08 AM
Poorb0i's Avatar
Default How do you lean out a D-Series engine??
How do you lean out a a D-Series engine? The reason why i want to do it is to increase gas mileage and. I just want to lean it out a little not enough to go to higher octane gas. Does advancing or retarding the timing do this? Obviously my car is stock except for intake so it should be safe to lean it out a little
Old Apr 22, 2008 | 09:35 AM
fillipo's Avatar
Default Re: How do you lean out a D-Series engine?? (Poorb0i)
reduce the amount of fuel
Old Apr 22, 2008 | 10:18 AM
hoo my gosh's Avatar
put a header and exhaust
Old Apr 22, 2008 | 10:42 AM
mistersparco's Avatar
washuuu
If you wanted to effectively achieve better mileage per gallon, I would:
Drive line a grandma (shift at a lower rpm, don't ride the brake pedal)
Put back on the stock airbox and filter
Complete a tune up if you haven't already
Make sure tires are inflated properly
Take out useless junk in the car
Change out the fuel filter
GO ON A DIET
"Leaning" the engine may have unforseen consequences.
Old Apr 22, 2008 | 11:59 AM
Poorb0i's Avatar
Put on header and exhaust really give better milage?? And putting stock air box in increases mileage also??????? I figure cooler air means greater amount of oxygen for each combustion so it would naturally lean a tad bit???? I know leaning the engine has its consequences, like detonation knocking but im not wanting to lean it out to that extreme. So how do i go about doing this without hondata chrome etc....... adjustable fpr perhaps??
Old Apr 22, 2008 | 03:11 PM
ddd4114's Avatar
You can chip your ECU and get it tuned. That may give you a slight boost in power and/or economy.
An intake, header, or exhaust can decrease economy depending on the design. If you minimize pumping losses, economy will improve. However, keep in mind that the engine and its systems have already been optimized for economy from the factory.
As stated, there are better ways to improve economy: be very gentle on the throttle, keep the tires inflated, etc.
Masho
Honda Civic (2001 - 2005)
Jan 14, 2011 09:04 AM
CivicNub
17
May 15, 2009 10:50 AM
94typeR
Jun 3, 2007 08:41 AM
blah13
Honda Motorcycles
11
Feb 8, 2006 01:39 AM
TomTom
Nov 26, 2001 09:14 PM
