tuned lean for mpg?
Ek Forever y0!
Re: tuned lean for mpg? (Project95LS-VTEC)
You'd have to tune for a proper a/f ratio, but you'd have to lean out air and fuel and change compression to do that.
It could be done. You'd have less power.
Go Tigers!
Re: tuned lean for mpg? (94typeR)
honda did, lean burn on the vtec-e engines, you won't get any better than that.
IIRC the p07 leans the engine out up to 17:1afr
But I don't really recommend playing with this unless you REALLY know what you're doing.
If you want better gas mileage I'd recommend doing a warm air intake to fool the IAT to lean your afr for you. Then work on decreasing drag and increasing aerodynamics. This are a hell of a lot simpler and effective than hacking the fuel and ignition maps.
SpoonFedHatch
02-24-2004 05:59 PM
