Who here has cracked their stock sleeves?
Old Jul 12, 2002 | 08:01 AM
Ri5e's Avatar
Default Who here has cracked their stock sleeves?
I was wondering who here has actually cracked their stock honda sleeves? And if so, how many lbs were you running and what kind of tuning did it have?
Old Jul 12, 2002 | 08:05 AM
VaporTrail's Avatar
New User
Default Re: Who here has cracked their stock sleeves? (BG Boost)
oooh oooh, I wanna be first in on this thread
I cracked my bored .20 over Honda sleeves. It was due to Crower's crappy *** cams breaking in four pieces (quin overhead cam baby) dropping a valve and smashing the whole motor into bits. Boost level = atmospheric.
Old Jul 12, 2002 | 08:19 AM
Ri5e's Avatar
Default Re: Who here has cracked their stock sleeves? (VaporTrail)
atmospheric, as it 0 psi? lol.
Old Jul 12, 2002 | 08:22 AM
VaporTrail's Avatar
New User
yeap, 0 psi, or full throttle n/a
Old Jul 12, 2002 | 08:24 AM
DSF's Avatar
DSF
Just check out my avatar It was a B16 block. 9200rpms on Gude valvespring (ie. they were stock ) . Broke the liner, sleeve, rod, piston, head, and bent the crank Oh, @0psi. Pretty impressive...I saved the parts as a memorial.
That was back when I knew nothing...after years of research, asking question, trial and error I have learned one thing since then...I have learned you can never know enough.
[Modified by DSF, 12:25 PM 7/12/2002]
Old Jul 12, 2002 | 08:34 AM
hybrid901's Avatar
Default Re: Who here has cracked their stock sleeves? (DSF)
B18c1 bored .20 12:1 endyn. Lean 130 shot. 2 cracked sleeves.
Old Jul 12, 2002 | 08:43 AM
FAST94GSR's Avatar
New User
Default Re: Who here has cracked their stock sleeves? (hybrid901)
that'll do it, LOL.
Old Jul 12, 2002 | 09:00 AM
APEX i GSR's Avatar
i've got a pic some where of what some shitty *** Toda cams did to a JDM ITR block & head. Cams shreadded the timing belt causing car to jump time bent 1 rod & destroyed combustion chamber. put hole in #1 piston & cracked cylider wall in 2 places
Old Jul 12, 2002 | 09:11 AM
Doodoo's Avatar
Cracked number 3 on my LS. 13psi seat of my pants tuning. dumb dee dumb dumb DUMB!!!
I have had great exercise for 3 months (walking).
[Modified by Doodoo, 4:27 PM 7/12/2002]
Old Jul 12, 2002 | 11:55 AM
Etylorcen's Avatar
Default Re: Who here has cracked their stock sleeves? (APEX i GSR)
Toda cams? I bet it was due to an improper install...
Old Jul 12, 2002 | 01:25 PM
jinxproof99's Avatar
New User
i'm trying man.......i'm trying........
Old Jul 12, 2002 | 01:39 PM
TypeC's Avatar
That doesn't sound like it had anything to do with the cams. It sounds like a cam gear or tension issue.
Old Jul 12, 2002 | 02:13 PM
91CivicSi's Avatar
Default Re: Who here has cracked their stock sleeves? (Etylorcen)
OT, but I think Toda cams require an aftermarket belt like Power Enterprises. Coquinn's Honda belt broke with Toda Cs.
Old Jul 12, 2002 | 02:38 PM
ezark's Avatar
Default Re: Who here has cracked their stock sleeves? (91CivicSi)
the B's don't require an aftermarket belt.
[Modified by gsR-T mode, 11:39 PM 7/12/2002]
Old Jul 18, 2002 | 10:23 PM
Ri5e's Avatar
Default Re: Who here has cracked their stock sleeves? (gsR-T mode)
ttt
Old Jul 18, 2002 | 10:41 PM
MiraiZ's Avatar
how does the car sound when you crack a sleeve...does it smoke white smoke pretty bad?
Old Jul 19, 2002 | 02:34 AM
boostaholic's Avatar
Default Re: Who here has cracked their stock sleeves? (MiraiZ)
Cracked number 1 cylinder wall. Stock B16A2, t3/t04b, 12psi. One too many 140mph runs White smoke covered a good 1/8th mile when it went.
fusion645
Dec 31, 2009 08:40 PM
b16bri
Feb 13, 2008 07:00 PM
b20vtech
Oct 2, 2007 02:14 PM
jon3zy
Apr 19, 2007 04:55 PM
hondaapi
Oct 29, 2006 06:29 AM
