civic coupe front suspension options
well i think its about time to tighten up my front end a bit, currently i have an h22 5th gen civic coupe sitting on omni full coilovers, omni camber kit upper strut bars front and back, aluminum lca's and a beaks rear tie bar. im going to be getting an asr rear subframe brace and 24 mm swaybar kit for the rear. my question is what would be some good options to stiffen my front end, sway bar, h brace, traction bar?
i heard H-bar or front lower tie bar improve handling.
for sway bar, it will be great if you can upgrade yours to 99-00 SIs (LCAs will have to be swapped tho) or ITR's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Ej1 »</TD></TR><TR><TD CLASS="quote">would i have to swap lcas to get the itr bar to fit? also are there any aftermarket companies that have a better front sway bar?</TD></TR></TABLE>
I am not 100% sure, but i believe you can use your stock LCAs for ITR front sway bar.
For the aftermarket, there are tons. ie, mugen, cusco, etc etc. I believe mugen makes 28mm? or 30mm? i dont know.. very thick tho
televascular
Suspension & Brakes
Apr 21, 2008 03:12 PM
95-EJ1
May 21, 2004 04:05 PM
gakkuken
21
May 23, 2003 02:29 PM
agent marlon
Oct 13, 2002 05:07 PM
