My Short Shifter Is Vibrating
Old Apr 21, 2008 | 07:47 PM
mateo5046's Avatar
Default My Short Shifter Is Vibrating
Hey guys so I just instaled a B&M short shifter ES poly shift bushings and a new type R boot on my 00 SI. Now I get a crazy vibrating noise from my shifter when its in 2nd and 4th gear. I cant figure out why itis doing this and its really annoying. Anyone have any ideas on what this might be and how i can fix it. I have a feeling its the sleeve that inserts into the botom of the shifter but im not for sure. Help me out guys thanks.
Old Apr 21, 2008 | 08:13 PM
mechanix619's Avatar
Default Re: My Short Shifter Is Vibrating (mateo5046)
Well, the poly bushings are going to stiffen things up a little, an increase in the vibrations is going to be normal. For example, if you install poly motor mount inserts the car is going to vibrate a lot more versus stock motor mounts.
Old Apr 21, 2008 | 08:17 PM
My JDM EJ8's Avatar
maybe your shifter is hitting your exhaust. i had the same problem on my EF
Old Apr 21, 2008 | 08:29 PM
Default Re: My Short Shifter Is Vibrating (My JDM EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My JDM EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">maybe your shifter is hitting your exhaust. i had the same problem on my EF</TD></TR></TABLE>
Great point. My O2 sensor actually rubbed against the shifter bar because I had an extender on the O2 sensor to act like a O2 simulator.
Old Apr 21, 2008 | 08:35 PM
Dasfinc's Avatar
the hangers on my aftermarket exhaust was clipping my shifter in 1st and 3rd, so if its resting against them in 2nd and 4th I'm sure that would cause a nasty vibration.
Old Apr 21, 2008 | 08:36 PM
97Ej6mike's Avatar
make sure all the bolts that hold the shifter assembly togather are tight as well. They can come loose over time. Also, as mentioned before, it can be worn shifter bushings, as well as bad motor mounts that send unneccesary vibrations on the linkage.
Old Apr 21, 2008 | 09:02 PM
mateo5046's Avatar
Default Re: (97Ej6mike)
i replaced the shifter bushings tho so the rattle sounds like its coming from the sleeve that the bolt goes through in the bottom of the shifter. Say imin 4th gear if it is in gear and i apply pressure by pushing the shifter to the left or the right the sound goes away.... Is there supposed to be rubber bushings that rest beteent the bottom of the shifterand thebracket that mounts to it?
Old Apr 21, 2008 | 09:06 PM
Default Re: (mateo5046)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mateo5046 &raquo;</TD></TR><TR><TD CLASS="quote">i replaced the shifter bushings tho so the rattle sounds like its coming from the sleeve that the bolt goes through in the bottom of the shifter. Say imin 4th gear if it is in gear and i apply pressure by pushing the shifter to the left or the right the sound goes away.... Is there supposed to be rubber bushings that rest beteent the bottom of the shifterand thebracket that mounts to it?</TD></TR></TABLE>
It sounds like an installation problem then, check all your bolts to see if everything is tight.
Old Apr 21, 2008 | 09:14 PM
mateo5046's Avatar
Default Re: (mechanix619)
I guess and im not trying to sound like I know everything but I know I installed it tight. I want to know if there are like rubber washers that sit up against the bottom ball of the shifter and the inside of the mounting bracket that bolts to the bottom ball. I feel like the sleeve that you push into the bottom ball of the shifter has a little space in the bracket and thats what is rattling....
Old Apr 21, 2008 | 09:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mateo5046 &raquo;</TD></TR><TR><TD CLASS="quote">I guess and im not trying to sound like I know everything but I know I installed it tight. </TD></TR></TABLE>
You aren't sounding like a know it all, you are more than entitled to stand by your work; if you did something right and you know it, stand by your wrench skills. You get props for having faith in your installation skills.
With that said, if your shifter came with rubber washers then it's probably a good idea to use them, or just tighten the bottom ball bolt so there isn't a gap.
Old Apr 22, 2008 | 01:14 PM
pilot03's Avatar
http://importnut.net/shifter.htm
Old Apr 22, 2008 | 02:19 PM
d357r0y's Avatar
I had this same problem: https://honda-tech.com/zerothread?id=1384740
You may now commence praising me.
Old Apr 22, 2008 | 02:35 PM
bmoua's Avatar
Default Re: My Short Shifter Is Vibrating (d357r0y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y &raquo;</TD></TR><TR><TD CLASS="quote">I had this same problem: https://honda-tech.com/zerothread?id=1384740
You may now commence praising me. </TD></TR></TABLE>
i might have to try this...my b&m SS rattles like no other when i'm above 5,000 rpm. During neutral it vibrates more than usual and it really gets annoying. I've installed the es bushings, which helped with smoother shifts and less vibration but the problem still hasn't gone away.
Old Apr 22, 2008 | 02:49 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mateo5046 &raquo;</TD></TR><TR><TD CLASS="quote">My Short Shifter Is Vibrating</TD></TR></TABLE>
Get on.
Old Apr 22, 2008 | 05:05 PM
JeffBro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">make sure all the bolts that hold the shifter assembly togather are tight as well. They can come loose over time. Also, as mentioned before, it can be worn shifter bushings, as well as bad motor mounts that send unneccesary vibrations on the linkage.</TD></TR></TABLE>
Ding Ding, Correct! That would be caused by a lose bolt holding the Short Shifter on to the U brace part of the linkage. Its ok tho cause your gonna end up putting the stock one back on eventually once you realize short shifters suck.
9818tegr
May 5, 2022 06:49 AM
Extreez
Dec 13, 2007 08:09 PM
CTR-GSR
Feb 24, 2006 09:47 PM
kaychi
Oct 6, 2005 01:24 PM
rasta420
Nov 25, 2004 09:57 PM
