kill switch...
Old Jul 12, 2002 | 06:46 AM
Ham'ed Hatch
Guest
Posts: n/a
Default kill switch...
hey what wires would i tap into for a kill switch?
and could i use just a regular toggle switch?
Old Jul 12, 2002 | 11:03 AM
bigblockEG's Avatar
Default Re: kill switch... (two.oh)
I am assuming that you are talking about a ghetto alarm kill switch. I do it in 2 ways. I put a blown fuse in the fuse box under the hood and run a switch to the ecu fuse.Make sure you add a fuse into the wiring of this switch, but it will cut power to the ecu... THe blown fuse is there as a decoy. You can also put a switch going to the hot wire of your fuel pump. If you do that one, make sure that you hide the toggle switch very well. Look at your haynes manual to find out which is the hot wire.
Didly
Audio / Security / Video
22
Mar 5, 2019 02:42 PM
thundernoodle
15
Aug 6, 2010 06:05 AM
tub_sephiroth
May 9, 2007 07:35 PM
92integraVTECgsr
Oct 10, 2005 09:14 PM
TurboTurtleGSR
Jan 17, 2003 09:04 PM
