Suspension & Brakes Theory, alignment, spring rates....
my ground control are JAMMED (pics)
Old Apr 21, 2008 | 06:29 PM
heredago's Avatar
Default my ground control are JAMMED (pics)
3 out of my 4 are jammed
the setscrews in the adjustable spring seats are full of SAND
I really don't know what to do
Old Apr 21, 2008 | 07:24 PM
egsleepercivic's Avatar
quit off roading lol, try tightening them, but be careful not to overtighten then spray out the side that doesn't have the hex head on it with brake cleaner, to try and get all the sand off the threads then hit with some wd type fluid then try to remove again.
gl
Old Apr 21, 2008 | 09:20 PM
Arthas's Avatar
Default Re: (egsleepercivic)
Do you have Coilover sleeves?
Old Apr 21, 2008 | 10:28 PM
bpr0422's Avatar
Default Re: my ground control are JAMMED (heredago)
some kind of cleaning fluid, and a pipe cleaner, you know those things that are fuzzy and positionable...
Old Apr 22, 2008 | 05:22 AM
heredago's Avatar
on the other side of the hex head, it's not open so I can't spray by there
I will try brake cleaner
Old Apr 22, 2008 | 07:26 AM
EK4civichatch's Avatar
Clean it with a tap and some brake cleaner...
Old Apr 22, 2008 | 07:43 AM
MaltBeer's Avatar
Default Re: (EK4civichatch)
When you put them back in use anti-sieze so you won't have that same problem the next time you go to adjust them.
Old Apr 23, 2008 | 09:25 AM
gabebauman's Avatar
Default Re: (MaltBeer)
Blow some canned air in there maybe too.
wezzel19
Mar 24, 2010 05:28 PM
matryx
Oct 5, 2007 01:08 PM
bs-inc
14
May 17, 2005 07:47 PM
HatchBox
Suspension & Brakes
13
Feb 6, 2005 08:34 AM
daebyuck
Mar 11, 2002 08:38 AM
