Help! H22 EG Avid mounts!!!!!!!
Old Apr 21, 2008 | 04:41 PM
cycopath's Avatar
* B A N N E D *
Default Help! H22 EG Avid mounts!!!!!!!
Hey I gotr may h22 in my eg with avid moutns everything is awesome expect one thing
For some reason my dirver side axle is binding up It looks like it is sitting at a 35 degree angle,. We tried shimming the tranny mount with washers and it helped alittle but not all the way.
I am using hasport axles, Can someone please help like ASAP!!
Old Apr 21, 2008 | 04:57 PM
irollerblade's Avatar
I thought the axels are supposed to sit kinda at an angle.
Old Apr 21, 2008 | 05:41 PM
cycopath's Avatar
* B A N N E D *
Default Re: (irollerblade)
Like I said, It's just permanet(sp?) binding, can't drive it as a result.
If I just get the accord intermeditate shaft with intergra axle will i be fine?
Old Apr 21, 2008 | 05:48 PM
A lil 2.3l action's Avatar
Default Re: (cycopath)
same problem here.... i had avids with my h22 eg and i had hasport axles... i ended up snapping my drivers side axle becasue of the same problem
the hasport axles are made to work with the hasport mounts and only those mounts...
what i ended up doing was using the accord half shaft with integra axles,, they worked perfect for me... you have to make sure you dont have alot of negative camber also or the passenger axle will pull out a lil on ya sometimes...
but when its all said an done i would invest in hasport
Old Apr 21, 2008 | 05:53 PM
cycopath's Avatar
* B A N N E D *
Default Re: (A lil 2.3l action)
OK cool thanks! Im just gonna keep the passenger side hasport axle I think and use integra on the driver side.
Old Apr 22, 2008 | 10:05 AM
FourBangerIndustries's Avatar
With the Avid mounts, you can use the an OEM axle combo. As long as you have a 90-93 Accord half shaft, you can use 90-93 integra axles no problem!
tealchief
Transmission & Drivetrain
Jan 28, 2010 08:35 PM
93Hammer
Feb 17, 2009 12:08 PM
vy3tnamezz
Aug 31, 2007 05:39 AM
djroven
Apr 12, 2007 08:44 AM
soon2b
Mar 14, 2005 11:34 AM
