P39 ecu
Old Apr 21, 2008 | 04:20 PM
true-elements's Avatar
Default P39 ecu
does anybody know where i can find a p39 ecu it is for jdm f22b dohc non-vetch engine.
Old Apr 21, 2008 | 04:22 PM
TheMuffinMan's Avatar
He knows where you live!
Run a chipped ecu - problem solved.
Old Apr 21, 2008 | 05:23 PM
ronqqq's Avatar
Default Re: (TheMuffinMan)
I just put a f22b dohc in my 94 accord,, Runs like carp.... spitting and no power.
You say run a CHIPPED ECU.. Do you know if this will fix that problem? and what chip is it that you run? Also how do you know this??
Thanks Ron
Old Apr 21, 2008 | 05:24 PM
If the ECU is chipped you can run whatever basemap you need off of it. So yes it will fix the problem.
Old Apr 21, 2008 | 05:30 PM
ronqqq's Avatar
Great... ok.. I am not familar with the chipped ecu... can you give me more info about them.. how to chip on... how can I tune it... where can I get one... What is this basemap??
Modified by ronqqq at 6:38 PM 4/21/2008
Old Apr 21, 2008 | 05:50 PM
Searchizzle
namely look at the Engine Computer Management/Tuning forum lower down the main page.
P28 is probably the best bet, then chip it, then find the correct basemap
Old May 1, 2008 | 04:15 PM
ronqqq's Avatar
ok ,, I got the rough running problem solved!!
Now, Has anyone found a source for the P39??
Old May 1, 2008 | 07:57 PM
Default Re: (ronqqq)
thats very hard and rare to find run a chipped p28. but if u lucky you could try ebay.just got mine for $150..
Old May 7, 2008 | 05:18 PM
ronqqq's Avatar
Default Re: (true-elements)
Just for future info!! My stock ECM from my 1994 accord ("po8" I think) does run my DOHC F22b GOOD!!
Was no need to get another one...
Old May 7, 2008 | 06:07 PM
v4lu3s's Avatar
RTFM
a p08 is not an accord ecu...that is a jdm sohc vtec ecu with a 1 wire o2 sensor.
did you mean a P0B ? If so that one should work well enough though its not ideal for power.
Old May 8, 2008 | 06:52 PM
ronqqq's Avatar
Default Re: (v4lu3s)
Hummm,,,, Yea I guess it is,,, I didn't pull the ECU out and the light was a bit low.
I guess your saying that I am not getting the full potential power using the stock ECU?
Old May 8, 2008 | 06:57 PM
v4lu3s's Avatar
RTFM
the stock ecu is for a sohc engine making 130 hp.
you have an engine designed with 2 cams and 160 hp in there. see a problem yet?
Old May 8, 2008 | 07:26 PM
ronqqq's Avatar
OK I can see that!! Let me ask you this,,, How would you suggest fixing this prob, I prefer to keep the ECU that I have. I see these chips for sale,,, what is the deal with those?? Does my ecu have a changeable chip? How do I find the one that would be suitable for my engine and car??
Can you tell me exactly what the chip does? What would be the diff with my ecu and the correct ecu (what does it do diff to the engine to get better performance?)
Thanks Ron
Old Jun 9, 2008 | 02:08 PM
RhdRicheeee's Avatar
I have a jdm p39 ecu
PM me
Old Jul 8, 2010 | 06:17 PM
94ludef22b's Avatar
Default Re: P39 ecu
Do you still have that p39? If so plz email me @ m.frazier1023@gmail.com
Old Jul 8, 2010 | 06:39 PM
GhostAccord's Avatar
Default Re: P39 ecu
Odds are that he has probably sold it or made use of it over the past two years.
Old Jul 14, 2010 | 05:32 PM
Default Re: P39 ecu
me? ya I do
Old Jul 15, 2010 | 06:59 AM
PTVDesign's Avatar
Default Re: P39 ecu
i have p39 n50 - 140 shipped
djkina
Engine Management and Tuning
Sep 19, 2018 05:36 AM
Vtec140
Oct 3, 2017 02:15 AM
speed_demon018
Jun 4, 2009 02:05 PM
LS stretch
Feb 3, 2009 08:40 AM
95lscivic
Aug 15, 2006 11:38 PM
