f22 swap into a Del Sol
Old Apr 21, 2008 | 12:56 PM
yoRt's Avatar
Default f22 swap n2 a soL
ok, first off is i have a 96 del sol, which is obd2a. i found a 95 accord with an f22b1, which i can get for 150 bucks, full longblock, it includes the full engine wiring harness too, and i know where to get the factory ecu for it for about 40 bucks. so i can spend about 200 bucks and have the ecu, motor, wiring harness, so all i would need is the cables and tranny. my question is, would i need to buy a jumper harness for the motor to work in my car? how hard would it be to put in as far as the wiring goes? im not worried about the cutting and welding, mainly the wiring. i want to do the f22 because i like single cams, and its very unique. i dont want an h22 or b18c5 or turbo d, n/a f22.
any info would be helpful
Old Apr 21, 2008 | 01:00 PM
superfast666's Avatar
Default Re: f22 swap n2 a soL (yoRt)
it would be exactly like a h22 swap just search or at the beginning of this fourm is a sticky that explains everything
Old Apr 21, 2008 | 01:03 PM
yoRt's Avatar
Default Re: f22 swap n2 a soL (superfast666)
ill try that out. thanks dude
Old Apr 21, 2008 | 07:02 PM
yoRt's Avatar
ive been reading alot about doing the swap, i was wondering, do i use my stock wiring harness? i currently have a d16y7 in it, non-vtec, going 2 a f22b1 vtec. would i even need the f22 harness? what about the ecu? should i use an f22b1 if i can find one?
Old Apr 28, 2008 | 10:45 AM
yoRt's Avatar
anybody?
Old Apr 28, 2008 | 11:36 AM
Dasfinc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoRt &raquo;</TD></TR><TR><TD CLASS="quote">ive been reading alot about doing the swap, i was wondering, do i use my stock wiring harness? i currently have a d16y7 in it, non-vtec, going 2 a f22b1 vtec. would i even need the f22 harness? what about the ecu? should i use an f22b1 if i can find one?</TD></TR></TABLE>
If you are afraid of wiring, you shouldn't be doing a hybrid swap IMO.
You will need to lay Vtec wiring from the solenoid all the way to the ECU, and yes, you should use a F22B1 ECU, do not try to run it on the stock Y7 ECU or it will pop.
Old Apr 28, 2008 | 12:10 PM
yoRt's Avatar
Default Re: f22 swap n2 a soL (Dasfinc)
i never said i was afraid of wiring, im just trying 2 get as much info as possible for this swap. i dont plan on using the y7 ecu cuz its not vtec and the f22 is, i can pick up an ecu from a 95 or 96 ex 5spd for cheap so i was g2 use that.
Old Apr 28, 2008 | 01:24 PM
Dasfinc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoRt &raquo;</TD></TR><TR><TD CLASS="quote">i never said i was afraid of wiring, im just trying 2 get as much info as possible for this swap. i dont plan on using the y7 ecu cuz its not vtec and the f22 is, i can pick up an ecu from a 95 or 96 ex 5spd for cheap so i was g2 use that.</TD></TR></TABLE>
95 is OBD1, so it would have to be out of a 96 manual accord
Old Apr 28, 2008 | 02:27 PM
fatboy1185's Avatar
Big Cat
there is companies that will do all the wiring for you at a pretty decent price, you just send them the wire harnesses
Old Apr 28, 2008 | 06:04 PM
yoRt's Avatar
Default Re: f22 swap n2 a soL (fatboy1185)
do you know any of the names of companies that do so? i can send the wiring harness for the f22 2 that company and have them do it or whatever. if i go obd1, do i have to worry about the egr valve and the charcoal canister and stuff like that? like those can all be removed correct?
Old Apr 28, 2008 | 06:39 PM
Dasfinc's Avatar
'painless' does some fantastic work I've been told.
Old Apr 29, 2008 | 10:47 AM
yoRt's Avatar
is 'painless' his name? anybody know of a place to pick up some press fit wrist pin pistons for a reasonable price?
Old Apr 29, 2008 | 12:48 PM
fatboy1185's Avatar
Big Cat
search rywire i believe?
Old Apr 29, 2008 | 08:57 PM
yoRt's Avatar
so ive been hearing alot that i should run an f22a1 head, because they flow a lot better than the b2, is this correct? are they still vtec?
Old Apr 30, 2008 | 08:17 AM
i can wire up the harness for you
Old Apr 30, 2008 | 06:47 PM
yoRt's Avatar
what makes the f22ax heads better than the b2? you would think that vtec makes more power. i wanted 2 get the b2 head port the hell out of it.
avianman
10
Mar 21, 2009 04:29 PM
nix94delsol
Jul 16, 2008 11:02 PM
loveda07
Jun 8, 2008 09:50 AM
slksol
Aug 25, 2003 08:41 PM
wbb6
17
Apr 16, 2003 08:58 AM
