clutch engagement problem
Old Apr 21, 2008 | 09:41 AM
the ludee's Avatar
Default clutch engagement problem
When i woke up this morning my clutch engagement point was much sooner then usual. anyone know whats going on?
4th gen
Old Apr 21, 2008 | 10:11 AM
CentralCalLude92's Avatar
Default Re: clutch engagement problem (the ludee)
Most of the time it is a leak.
Check lines and check the slave and master cylinder.
Inspect them really good as it is tuff to tell sometimes that they are leaking.
Old Apr 21, 2008 | 10:53 AM
the ludee's Avatar
Default Re: clutch engagement problem (CentralCalLude92)
would this literally happen over night?
Old Apr 21, 2008 | 11:38 AM
CHK4TIX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the ludee &raquo;</TD></TR><TR><TD CLASS="quote">would this literally happen over night?</TD></TR></TABLE>
yes it can, things have go give out some time. If it is a small leak you might not have noticed it until today, but it could have had symptoms for a while now
Old Apr 21, 2008 | 03:25 PM
the ludee's Avatar
Default Re: clutch engagement problem (CHK4TIX)
well i just got back from school and its all back to normal :/
Old Apr 22, 2008 | 07:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the ludee &raquo;</TD></TR><TR><TD CLASS="quote">well i just got back from school and its all back to normal :/ </TD></TR></TABLE>
Well hopefully it will stay that way. But it sounds like the start of intermittent engagement point problems. Just make sure you keep an eye on it.
Old Apr 23, 2008 | 03:12 PM
the ludee's Avatar
alright well i tried it again today and i couldnt get it in gear at all so i went and checked the fluid and it was empty. so i'm going to try to find a leak is this going to be something possibly easy to fix?
Old Apr 23, 2008 | 04:41 PM
dagle's Avatar
master cylinder.. its probably leaking internally... check under your floormats on driver side.. where the pedals go.. u should be able to feel a greasy wetness
Old Apr 23, 2008 | 06:00 PM
the ludee's Avatar
Default Re: clutch engagement problem (dagle)
i got the master cylinder changed a yearish ago. I just bled the clutch and all seems well for now.
B18C5-EH2
21
Nov 12, 2007 04:09 AM
jonnytuner
Mar 4, 2006 04:06 PM
-JSpecEk*9-
Aug 13, 2005 02:09 PM
vtec_addict
Mar 23, 2004 04:07 AM
Airmax55555
Dec 29, 2003 01:35 AM
