running on 3 cylinders??????
Old Apr 21, 2008 | 06:54 AM
DeleriouS25's Avatar
Default running on 3 cylinders??????
so i finally get my freshly built b20 started. it didnt sound quit clean when i started up, and i didnt think it was running right. well my paps pulled off the plug wire to the driver side piston (#4?), and the car didnt miss a beat, i figured something was up. so i checked the plugs - and i am getting spark.
so i figured it was the used 450s i had in there. well i swapped 2 of the injectors, and it still was not firing on #4. so i rewired my wiring job that i had to splice into the stock harness - got nothing. so i figured maybe it was one of the resistors in the resistor pack that blew, so i got another one, wired it in, and still only firing on 3 cylinders. this is the bad part then.
i have no idea what could be causeing this. it has a flaw somwere past the resistor pack. has anyone ever had this happen to you??? thanks for your time guys
Old Apr 21, 2008 | 09:17 AM
Default Re: running on 3 cylinders?????? (DeleriouS25)
i checked the resistance on the wire coming from the harness to the injector clip. i am basically getting nothing out of it. soi start the car and i go to the harness and i am getting about 1-2mV on that injector, and about 6-8mV on the other injectors???
Old Apr 21, 2008 | 01:20 PM
90efhatch's Avatar
Is the ecu known to be good? Try another and see what happens.
Old Apr 22, 2008 | 03:38 PM
Default Re: running on 3 cylinders?????? (90efhatch)
yes. I believe the ecu is working correctly. I wired in the 450s with the resistor pack, so i am sure i just dont have a good enough connection somewhere down the line. guess im going huntin...
Old Apr 25, 2008 | 02:47 PM
vtecb18c's Avatar
can you hear any pulse in your last injector?
LuckyStrike90
Aug 2, 2024 12:10 AM
Arthas
Mar 3, 2010 05:08 PM
a1320honda
Sep 23, 2007 01:06 PM
joshb_
Sep 30, 2005 06:44 PM
SOFLSOL
Jul 30, 2003 09:42 PM
