B18b turbo camshaft question
Old Apr 20, 2008 | 04:54 PM
Panda Eg6's Avatar
Default B18b turbo camshaft question
My friend who grinds cams is making me custom cams for my Ls-T setup with the oem cams, I was just wondering if I would need to upgrade the valvetrain as well or would it be fine.. Thanks
Old Apr 20, 2008 | 04:59 PM
turbociv910's Avatar
Default Re: B18b turbo camshaft question (Panda Eg6)
i would, upgrading ls springs is a cheap alternative to a dropped valve.
Old Apr 20, 2008 | 05:07 PM
Panda Eg6's Avatar
Default Re: B18b turbo camshaft question (turbociv910)
any one else? How are their retainters? worth the money to upgrade?
Old Apr 20, 2008 | 08:33 PM
Panda Eg6's Avatar
Bumppppp still need to know
Old Apr 20, 2008 | 08:56 PM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Well first i would ask how aggressive will the regrinds be, but either way anything above factory specs i would definitly upgrade. Its really not that expensive and like stated is worth not floating a valve. Mainly i would be worried if you were plannin on revving higher than factory redline.
Old Apr 21, 2008 | 08:12 AM
Panda Eg6's Avatar
Default Re: B18b turbo camshaft question (ForceFed Motorsports)
Yea that is a good point, if I ended up not putting in aftermarket springs then I would definately not rev over the stock redline.
I think I well end up buying some valve springs, also wanted to know if it was worth buying retainers as well- or if that is just a waste of money.
Also I am doing my build with a budget and was wondering what kind of valve springs you guys would recommend.
Thanks
Old Apr 21, 2008 | 08:36 AM
You can find combo sets that are a good deal with both springs and retainers. I would recommend it while your in there. Do it once and do it right
Old Apr 21, 2008 | 09:19 AM
CX-T's Avatar
If the head is stock you don't need to upgrade it.
Old Apr 22, 2008 | 08:19 AM
Panda Eg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">You can find combo sets that are a good deal with both springs and retainers. I would recommend it while your in there. Do it once and do it right </TD></TR></TABLE>
True
Thanks
the.hamburglar
Dec 27, 2005 04:03 PM
jaydm7182
Nov 2, 2005 05:48 PM
dohcter g
Oct 17, 2003 05:17 PM
jdm4life
Oct 10, 2003 10:55 AM
CRXSleeper
Sep 9, 2002 10:47 PM
