Suspension & Brakes Theory, alignment, spring rates....
how much will i gain with sway bars?
Old Apr 20, 2008 | 03:46 PM
95 civic turbo_gsr's Avatar
Default how much will i gain with sway bars?
i have a 95 civic with full tein suspension dropped about an inch or so, all suspension bushings have been replaced with polyurethane ones, front upper strut bar and a rear lower strut bar. also front and rear gsr brakes. my question is how much would i gain if installed front and rear sway bars? will it be worth the money/time? thanks
Old Apr 20, 2008 | 05:15 PM
SilverCoupeEj8's Avatar
Default Re: how much will i gain with sway bars? (95 civic turbo_gsr)
10 to 15 hp... rephrase your question....almost always upgrading from stock will give you benefit's...depends on which product you go for(price wise)
Old Apr 20, 2008 | 08:06 PM
user 98292739's Avatar
IMO sway bars are one of the best mods you can do.
i run a comptech rear 22m sway wiht brace and car is amazing around corners.
Old Apr 20, 2008 | 08:30 PM
Default Re: how much will i gain with sway bars? (SilverCoupeEj8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverCoupeEj8 &raquo;</TD></TR><TR><TD CLASS="quote">10 to 15 hp... rephrase your question....almost always upgrading from stock will give you benefit's...depends on which product you go for(price wise)</TD></TR></TABLE> will i notice a big diff with how the car handles if i install sway bars? i wasn't asking about hp thats why I'm posting this in the suspension category.
Old Apr 20, 2008 | 08:39 PM
oh yes...def feel the difference.
during slow speeds not so much, but higher speeds the car is flat and it feels like you can just keep pushing it and it wont break loose.
Old Apr 20, 2008 | 09:12 PM
vietnameeh's Avatar
youll add about 10-20lbs to the car
haha
but ya sway bars are definitley worth it
Old Apr 21, 2008 | 12:14 AM
Default Re: (vietnameeh)
i have a dx model civic so it didnt come with anything stock. does anyone know of where i can get a front and rear sway bar setup that will come with everything i need to install it? i'm looking to spend $300 or less.
Old Apr 21, 2008 | 01:22 AM
bpr0422's Avatar
imo, save up your money, for a set of dampers(shocks) and springs.
sway bars are used to fine tune the suspension...
springs will give you a bigger difference, then good dampers..
Old Apr 21, 2008 | 07:28 AM
vietnameeh's Avatar
u can use suspension techniques sway bars... they have a kit for DXs tht came no sway bars everythin gyou need
Old Apr 21, 2008 | 08:17 AM
you dont need a front sway bar yet. get the rear bars first.
ASR comes in a kit for around 350 i believe. you could go smaller and go for a mf facotry one for 190 shipped.
Old Apr 21, 2008 | 08:24 AM
omnirage's Avatar
I just picked up a Progress 22mm rear sway for my teg. Best bang for the buck mod EVER.
$160 and I'm almost driving a new car...seriously. It's a whole new monster when you whip it around the corners.
Old Apr 21, 2008 | 08:59 AM
Default Re: how much will i gain with sway bars? (bpr0422)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 &raquo;</TD></TR><TR><TD CLASS="quote">imo, save up your money, for a set of dampers(shocks) and springs.
springs will give you a bigger difference, then good dampers..</TD></TR></TABLE> i already have a set of tein dampers and springs.
Old Apr 21, 2008 | 04:56 PM
bpr0422's Avatar
then get an asr brace, and a 22mm rear bar, see how it is.. too stiff, go smaller, too tail happy, add a front sway...
what exactly do you not like about your current setup?
too much understeer, body roll??
if its understeer, then a stiffer rear...
body roll can be sorta fixed with a rear bar, but it may oversteer...
it really depends on what you want to improve
Old Apr 21, 2008 | 05:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 &raquo;</TD></TR><TR><TD CLASS="quote">then get an asr brace, and a 22mm rear bar, see how it is.. too stiff, go smaller, too tail happy, add a front sway...
</TD></TR></TABLE>well right now i want to get rid of some body roll. the strut bars helped alittle bit but i want it better. i just ordered some rims and tires, so that should help. i'm putting some 15" drag rims and some falken 615's.
Old Apr 22, 2008 | 07:29 AM
kabaroo's Avatar
I have had my hatch set up with a 22 bar in the rear with nothing in the front... I would not recomment it.. Front will dive while the back is rigid. It was very tail happy when i had bad tires, have not pushed it on azenis. Its been mostly a drag car w/ the bar removed but i would like to add an dc2 front bar!
Sway bars ftw, get them before strut/bracing bars cuz sway bars actually WORK, but you cant see them as well as that shinny anodized aluminum strut bar
Old Apr 22, 2008 | 08:32 AM
dpetro1's Avatar
PMed you.
Old Apr 22, 2008 | 09:00 AM
Default Re: how much will i gain with sway bars? (dpetro1)
anyone know a site i can buy some swaybars at?
Old Apr 22, 2008 | 09:19 AM
yc_dc4mar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 civic turbo_gsr &raquo;</TD></TR><TR><TD CLASS="quote">anyone know a site i can buy some swaybars at? </TD></TR></TABLE>
check out the asr kit at there website or weksos has it i want it bad but im broke
Old Apr 22, 2008 | 09:23 AM
dpetro1's Avatar
Default Re: how much will i gain with sway bars? (yc_dc4mar)
i have a kit for sale. check your PM. you can run something like the ASR brace but i think it will require new LCAs.
EFstyle
14
Aug 23, 2007 06:18 PM
96_GSR
Jun 10, 2002 03:32 PM
01gizzer
May 29, 2002 01:27 PM
Diversion
Mar 1, 2002 04:11 PM
Jordan_4WS
Feb 22, 2002 12:41 AM
