Running LEAN!!
Old Apr 20, 2008 | 02:20 PM
bigizsosexy's Avatar
Default Running LEAN!!
hey everyone,
My b16 delsol is running lean i believe, the plugs are white with some black residue on the top threads.
Buring coolant or running too lean....
Any idea how to fix it?
Old Apr 20, 2008 | 03:41 PM
Former User's Avatar
Default Re: Running LEAN!! (bigizsosexy)
Is the Check Engine Light (CEL) ON?
https://honda-tech.com/zerothread/1901557
Do a compression test on the cylinders (head/head gasket problem) if you think the engine is burning coolant.
Old Apr 21, 2008 | 05:43 AM
Default Re: Running LEAN!! (RonJ@HT)
Cel is on, I havn't read the code yet.
I just recently changed the head gasket and it may be the head is warped so maybe its coolant burning not sure 100 percent.
Old Apr 21, 2008 | 05:51 AM
slo_hatch's Avatar
o2 sensor problem? check the codes and find out why your cel is on.
Old Apr 21, 2008 | 06:09 AM
JDMeGGaLLdAY's Avatar
Yes, def. start by check'n codes and go from there
Old Apr 21, 2008 | 11:26 AM
Default Re: (JDMeGGaLLdAY)
ok i ll start from there and report back.
Old Apr 21, 2008 | 11:48 AM
k heres the update: The cells are reading bad MAP sensor, Primary Oxygen Sensor, and Iacv.
I recently changed iac and is it that possible that that one is bad aswell or is there maybe a wiring problem?
Old Apr 21, 2008 | 03:41 PM
bump the fixie
Old Apr 21, 2008 | 03:45 PM
bigsyke's Avatar
would that be a ground issue?
thermostat ground.
Old Apr 22, 2008 | 11:05 AM
Default Re: (bigsyke)
not sure i can check. I am going to change all sensors soon and if that doesn't fix it its gotta being a wiring issue
Old Apr 23, 2008 | 05:31 AM
Bump need it
Old Apr 23, 2008 | 05:32 AM
I am going to check to see if all sensors are bad, by replacing them obviously. If not I am going to assume its a wiring problem
Old Apr 23, 2008 | 07:57 PM
Bump
Old Apr 23, 2008 | 08:25 PM
hondaboostin's Avatar
when you replace the iacv did you reset the ecu? and the map has a lot to do with the way a car runs. it senses the pressure and lets the ecu know how much gas to give it. But then again so does the o2 sensor. It reads if its lean or rich and tell the ecu to give it more gas or less gas. So if both happen to be bad then it will run lean or rich cause it has no way of knowing if its running rich or lean. Hopefully this info will help you check to see if the sensors are bad if not you'll know what you dont have... 5 volts power, ground or signal. VOLTAGE
At 5 in.Hg 2.4 Volts
At 10 in.Hg 1.9 Volts
At 15 in.Hg 1.5 Volts
At 20 in.Hg 1.0 Volts
At 25 in.Hg 0.5 Volts
PURPOSE
The ECU uses the MAP sensor signal to sense engine load so that ignition timing and fuel delivery can be adjusted to maintain consistent engine performance.
LOCATION
The manifold absolute pressure (MAP) sensor is mounted to the rear wall of the engine compartment.
CONSTRUCTION
The sensor consists of a silicon diaphragm and some support circuitry.
OPERATION
The ECU supplies a 5 volt signal and a ground to the sensor. A vacuum line supplies intake manifold vacuum to a small cavity under the silicon diaphragm which causes the diaphragm to flex. The flexing of the silicon generates a small voltage which is amplified by the support circuitry and used to modify the fixed 5 volt signal supplied by the ECU. The modified signal is then returned to ECU.
hope it helped some.
EkFG's Avatar
your o2 might have **** on it and be bad a map sensor would most def trigger this. I would start be replacing both and reset computer.
Old Apr 24, 2008 | 12:20 PM
Default Re: Running LEAN!! (EkFG)
ok got one comiing in tomorrow thanks guys I ll update ya
Old Apr 25, 2008 | 11:32 AM
Ok heres the update, Map sensor was changed out and cell 3 went off. Thats the good news. I changed O2 sensor ( with Brand new one) but no difference cell 41 is still on and so is cell 14. Those two cells i need to fix any ideas.
Old Apr 25, 2008 | 04:15 PM
Updated!
Old Apr 25, 2008 | 06:59 PM
slacks's Avatar
run some seafoam to clean your pcv lines and clean out your iacv.
Old Apr 25, 2008 | 07:48 PM
slowcivic2k's Avatar
A grayish white tan color and soot on the bottom of the plug threads with a white electrode indicate a plug in good condition. No cause for alarm.
Old Apr 25, 2008 | 08:47 PM
bigsyke's Avatar
Default Re: Running LEAN!! (slacks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slacks &raquo;</TD></TR><TR><TD CLASS="quote">run some seafoam to clean your pcv lines and clean out your iacv.</TD></TR></TABLE>
that will further make him run lean. clogged IACV and/or PCV means less air in the mix.
Old Apr 27, 2008 | 07:59 AM
Default Re: Running LEAN!! (bigsyke)
Will do so, getting head resurfaced this weekend will report back after I put everything back together.
THanks again guys
Old Apr 27, 2008 | 09:47 AM
yoffer's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigizsosexy &raquo;</TD></TR><TR><TD CLASS="quote">Will do so, getting head resurfaced this weekend will report back after I put everything back together.
THanks again guys</TD></TR></TABLE>
Why? Are you burning coolant?
Is there white smoke coming from your tailpipe?
Old Apr 27, 2008 | 10:14 AM
bigsyke's Avatar
14 is iacv right? yea its probably NOT the sensor. The IACV code will go off on alot of counts. Vac leaks and an improperly adjusted throttle cable are the #1 reasons for code 14/IACV
Old Apr 27, 2008 | 05:24 PM
ok i ll deff look into the throttle cable thing and because the head was leaking oil. and head needs to be resurfaced bro.
Noticeable leaking.
wallendiaz
Nov 27, 2012 01:31 PM
jyacoba2009
Sep 28, 2009 09:03 PM
all-mtr-teg
Nov 5, 2007 04:55 PM
law_teg_92_R
Jun 13, 2005 05:31 PM
Tad
Feb 21, 2005 04:14 PM
