help?
1. Every time that I drive around my idle is starting to go low why is that?
2. When I'm driving around my over flow tank makes noises and i guess i could see the green coolant , that I put in radiator.
A little bit more information would be helpful.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dorkjoey »</TD></TR><TR><TD CLASS="quote">1. Every time that I drive around my idle is starting to go low why is that?
This could be because a few different things. Please give a little history.
2. When I'm driving around my over flow tank makes noises and i guess i could see the green coolant , that I put in radiator. </TD></TR></TABLE>
This is normal. Seeing coolant in the overflow tank is good, seeing nasty grimy fluid is bad.
A history here it goes it's d16z6 and has about 175,xxx something miles on it. Before it would overheat so...I changed out timing belt, water pump, thermostat. Behind 0 or one line of needle my car would die. Btw I changed oil, but I don't know oil is causing it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mechanix619 »</TD></TR><TR><TD CLASS="quote">A little bit more information would be helpful.
This is normal. Seeing coolant in the overflow tank is good, seeing nasty grimy fluid is bad. </TD></TR></TABLE>
well...my over flow always making splash sound. So....im wondering if I need some new radiator ? and also when green coolant goes to coolant I can see the nasty part in radiator it looks nasty.
Are you adding any coolant or oil to your motor, because it's low? Is the coolant in the overflow still green? Is the coolant in the radiator green or nasty sludge? If your coolant isn't Green, and looking like some nasty brown/tan sludge, then you probably do have a blown head gasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dorkjoey »</TD></TR><TR><TD CLASS="quote">1. Every time that I drive around my idle is starting to go low why is that? </TD></TR></TABLE>
When you say "starting to go low" what do you mean? When you start you car up, does it idle fine? If you let it idle for 5-10 minutes does anything change?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TahitianEG »</TD></TR><TR><TD CLASS="quote">Are you adding any coolant or oil to your motor, because it's low? Is the coolant in the overflow still green? Is the coolant in the radiator green or nasty sludge? If your coolant isn't Green, and looking like some nasty brown/tan sludge, then you probably do have a blown head gasket.
When you say "starting to go low" what do you mean? When you start you car up, does it idle fine? If you let it idle for 5-10 minutes does anything change? </TD></TR></TABLE>
when car starts fine , but after while rpm needle will go down and almost hit the 0 and motor kinda shakes.
well...how do I fix the blown head gasket?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk92_d16 »</TD></TR><TR><TD CLASS="quote">It does sound like the HG...that bubbling you hear in the overflow is a good sign of that.</TD></TR></TABLE>
why is that?
why is that?
itralex
Feb 26, 2006 04:09 PM
