1995 Eclipse Gst
ITS OBO MAKE DECENT OFFERS..NO TRADES
I have a 1995 Eclipse GS-Turbo. It has a 1999 front end conversion and a rear. Here is a little information about the car. I bought it with a blown turbo bad oil leak and untuned that needed some work. Since then i have put a 14b turbo on it. Fixed all the small mechanical problems it had and had it tuned. It was fixed by a very good guy that knows everything there is to know about DSM's. It
does need some work.. I do have the backseats and everything. If buyer wishes i will put them back in. Since i owned it i have only put Royal Purple in it. The car laid down 250whp/270tq on stock motor with the 14b. If you get some bigger injectors you will be well over 300 on 20lbs. Had spark knock so i couldn't do anything bigger. Aslo have turbo timer that isn't hooked up
Email me if you wish to know more about it. Wanting this gone soon!
Good:
New turbo. I was told 1000miles on rebuilt when sold to me. So 2000miles on it now.
No vacuum leaks.
SAFC II Tuned
Cars runs strong and pulls hard.
255 Walbro Fuel Pump
Apexi 3" downpipe
Bad:
needs a new passenger side door handle. ill have it replaced before sale.
Needs some rear quarter panel work.
Hatch needs attention
Front and Rear bumpers aren't the same color. You can only tell in broad daylight if you look at it.
**Needs new Vss and Oil return line. ** only bad thing ...doesnt leak bad at all..one or two drips over night.
I can get the stock front bumper and rear but this one looks better if painted.
Im asking 4200 w/o the VSS and Line fixed. or 4500 with them fixed..I can get the both parts for 130 together if you wish.
Pictures.
[IMG]http://i28.tinypic.com/2z9dxu0.jpg[/IMG]
[IMG]http://i31.tinypic.com/f3cayg.jpg[/IMG]
[IMG]http://i26.tinypic.com/2je5ymb.jpg[/IMG]
[IMG]http://i31.tinypic.com/k34ta9.jpg[/IMG]
[IMG]http://i27.tinypic.com/iodpvc.jpg[/IMG]
Thanks
Modified by chadalac1712 at 2:53 PM 4/20/2008
dyno sheet..http://img520.imageshack.us/img520/1210/picturegc6.jpg
note..i did have it tuned on 20lbs...but it had spark knock..needs some bigger injectors and you good for 21lbs on the stock 1g bov.
HT Username
Oct 26, 2005 06:15 AM
NewIntegraKid
Sep 29, 2002 04:30 PM
