Tips on Painting my b18a Block?
i used a can last summer and did my block and trans i thought it was doing fine i had a leak sprayed some brake clean and took the paint off so go get it powder coated is what i suggest
Degrease the block , then sand it with 600 ( if you want to remove the texture then you will have to start with 80 and work your way uo to 600) Then prime the block with the proper primer for aluminum and the primer sealer over that...wetsand it smooth again, sela it, base it then a couple coats of clear. And yes base clear will stick to the block and last a long time if you do it right.
