PLEASE HELP!! Can't turn key in ignition
I drove my car( 92 hatch ) to get some lunch yesterday and when i came out i tried to put the key in and start the car....well it will go half way to the first position, just enough to freely turn the wheels and that's it. the key will not go any further. i turned the wheels every way possible and still nothing. i was going to pull the ignition crap out and just use a toggle switch to turn on the accessories and then use a push button to start.....then i was going to buy one of those steering wheels with the quick releases( racing steering wheel ) on them to prevent theft can anybody tell me which wires i need to hook up to the toggle switch and to the push button. thanks a lot in advance.
well heck i would settle for any suggestions as to getting the key to turn....im afraid they are gonna tow my car from the parking lot soon
just sounds like ur steering wheel is locked but im sure its something else just not sure what what cause it to do that? i know its dumb but u try moving the steering wheel around while tryin to turn key
Here you go. Follow the steps that are underlined in blue to start your car.
or to replace the whole lock and cylinder
http://www.tegger.com/hondafaq/lockcylinder.jpg
http://www.tegger.com/hondafaq/igntionswitch.jpg
Larger Image of How to Start Car:
http://img329.imageshack.us/im...1.jpg
4:20
4:20
AWESOME!!!! thanks man youre a life saver. now that's a redneck ignition system...hehe so would i need to make the push start like this...
Toggle Switch:
These wires on on side of the switch
White/Red
Blue/White
Black/Yellow
Yellow
and the White/Black wire on the other side
Push Start:
Black/White wire on one side and the White wire on the other
Modified by psychotic_civic at 9:30 AM 4/20/2008
Toggle Switch:
White/Red
Blue/White
Black/Yellow
Yellow
Push Start:
sure did....it is scary knowing that i never done anything like this in my life and it took me less than 3min to start my car with a screwdriver....i went outside and looked at the back of the ign switch and found which wires do what
Beige=Battery
Beige/Black=Acc
Black/Yellow=IG1
Black/White=Starter
Yellow=IG2A
So with this wiring how can i rig it up with a toggle switch and push start
This would be my guess:
Toggle:
Beige on one side
other side would be:
Beige/Black
Black/Yellow
Yellow
Push Start:
Beige on one side
Black/White on the other
Beige=Battery
Beige/Black=Acc
Black/Yellow=IG1
Black/White=Starter
Yellow=IG2A
Toggle:
Beige on one side
Beige/Black
Black/Yellow
Yellow
Push Start:
Beige on one side
