dash light stopped working
Old 04-16-2008, 10:08 AM
onesoejourner's Avatar
Default dash light stopped working
Some of my cluster lights have stopped working. The only lights that don't wark are the lights used to illuminate the speedo tech ect. the dummy lights are all still working. I have been testing the circuits and it seems that the + and - are both showing a continuous circuit. I really am frustrated at this point. The lights were working ok and occasionally they would go out but smacking the cluster usually brought them back on. now I am totally in the dark. Does any one have a wiring diagram for these lights and the dimmer? I have tried to trouble shoot this from the headlight switch to the dimmer and to the lights but I am not sure how everything is wired up so I am getting no where.
I found this diagram but its not really helpful.
the car is a 93 civic ex.
Old 04-16-2008, 10:13 AM
blk92_d16's Avatar
Tried messing with the rotary **** that controls the brightness settings? Mine started going out and if I bent the 3 pongs in back just right it'd turn back on. Stuff is getting old...
Old 04-16-2008, 10:14 AM
SinsEvil666's Avatar
Have you checked your fuses, though i find it hard that would be the problem since you say before you just smacked it and it worked.
Have you taken out the cluster gages and checked it? make sure bulbs are well in place and functional.
Old 04-16-2008, 10:46 AM
yeah I have tried messing with the dimmer.
I have checked the fuse, it is fine.
I had the whole dash apart and the cluster all the way out. If would like to just try connecting a direct 12v source to the cluster so make sure the lights work but I am not sure what wire I would need to hok on to. I doubt all the bulbs could have gone out at once so I am sure the should be good.
Old 04-16-2008, 12:09 PM
I believe you can pull out he bulbs from the cluster. Pull them out and check them.
Old 04-16-2008, 01:05 PM
Yes the bulbs are working.
Old 04-16-2008, 01:57 PM
Ok, im no help from here and on....i would suggest using friends cluster if any to test. If lights dont work on that one either, get wiring diagram and check the cables/plugs with a tester and start testing
Hope someone with more knowledge can help you.
Bump for answers
Old 04-17-2008, 05:06 AM
thanks man. Surely some one has a scanned wiring diagram?
Old 04-18-2008, 12:44 PM
bump for some one with a scanned wiring diagram.
Old 04-18-2008, 12:53 PM
Tonyej1's Avatar
Default Re: (blk92_d16)
exact same thing happened to me man
all i did was go to the junk yard get a new dimmer
switch change them out
and bam they work lol
i was pretty shocked
try it it should work for sure
Old 04-18-2008, 02:06 PM
does any one know what wires that go to the switch that I can stick together to confirm that its the dimmer? Thanks Tonyej1 you may be on to something.
Old 04-18-2008, 04:08 PM
b16delsolnewb's Avatar
Default Re: (onesoejourner)
i have the same problem with my dash. i havent done anything right now but doesnt make sense to check any fuses first?
Old 04-20-2008, 09:40 AM
Tonyej1's Avatar
Default Re: (b16delsolnewb)
yeah fuses of course you would always check
thats first
then you would just go down the line
but i did all the steps lol
and i just was thinking what else runs those dash lights
and its the dimmer switch so i just got one
and its just a unplug plug back in thing
try it and let me know man
hopefully it works
Old 04-20-2008, 09:50 AM
mercutio_07's Avatar
Default Re: (Tonyej1)
i had this same problem in mine. it started with the dash lights and evenutally affects the taillights. there is a ground wire by itself under the dash on the right side of the steering column. i took out my guage cluster to get too it, but later realized i could get to it from under the dash. it had a bad connection so i just cut off the original connector, replaced it, and screwed it back on. good as new.
88aeFC3S
01-03-2010 11:38 AM
slob20ef
03-30-2009 05:43 PM
aojtin
11-25-2007 06:36 PM
NatedoggAZ
02-10-2006 11:00 AM
ITR.#1446
12-27-2004 08:57 PM
Quick Reply: dash light stopped working
