SOHC JRSC woes...
Old Apr 19, 2008 | 06:13 PM
BigJ5's Avatar
Default SOHC JRSC woes...
Here is the setup...
d16y8 bottom end with a Z6 head
JRSC kit (obvi)
What I've done to the kit
Moved the MAP sensor to read manifold pressure
dsm 450cc with resistor box instead of fmu
NGK with a temp of 9
B16 throttle body
ported S tube
modified JRSC 3.4" 4 rib pulley
Y8 crank pulley
runs approx 9.5psi
P28 with neptune
NEVER intalled the intake temp sensor relay pressure switch
My woes...
The car is actually not quick, peppy or fast at all!!!!! (it is faster than stock, not by much tho)
experienced guys ---- DO I NEED this pressure switch?
What is the ecu doing when it sees intake temps higher than the water temp like its running right now under boost. ( I think its really retarding the ignition and doing something with the fuel maps)
IF i need the pressure sensor and relay to add resistance to the intake temp sensor, what is the resistance I need to add?
pls help....I know this kit is better than this....
Old Apr 19, 2008 | 08:06 PM
blinx9900's Avatar
Default Re: SOHC JRSC woes... (BigJ5)
try posting the 400page JRSC thread, im sure they can help you
protopro88
Apr 7, 2011 09:14 PM
C_Rock77
Dec 28, 2007 10:29 AM
keebler65
Jan 21, 2005 03:00 PM
Tad
Oct 24, 2004 12:35 AM
exciv2000
Dec 3, 2003 02:02 PM
