Car almost stalling. Need help Tech's.
Old Jul 11, 2002 | 08:56 PM
Heavy Pee's Avatar
Default Car almost stalling. Need help Tech's.
Over the past week and a half it has been doing this . When i'll go fast through the gears every now and then the engine will cut out . The engine light will come on and almost stall but i let off the gas and it goes back to running fine . When i drive it normal nothing abnormal happens . It usually happens when the rpms are above 4000 . I bought some fuel injector cleaner and that did not help . I bought a fuel filter and havent installed it yet . When I first got the car and would go fast through the gears I would shift at redline and the engine light would come on . The engine would sound like it cut out , but it would not affect anything.
Does anyone have an idea what might be wrong?
Old Jul 11, 2002 | 09:00 PM
EF_LSVtec's Avatar
Default Re: Car almost stalling. Need help Tech's. (Hvy P)
check fuel pump... cutting out on redline means rev limiter is engaging...what kind of motor?
Old Jul 11, 2002 | 09:02 PM
Heavy Pee's Avatar
Default Re: Car almost stalling. Need help Tech's. (EF_LSVtec)
It's a d16 no mods . It only does this in first and 2nd gear.
Old Jul 11, 2002 | 09:09 PM
Louie B.'s Avatar
get that fuel filter on there
Old Jul 12, 2002 | 02:16 PM
Heavy Pee's Avatar
Default Re: Car almost stalling. Need help Tech's. (thumpu77)
A guy on my local message board said this might be whats wrong.
" Sounds like the duty cycle it to high on the injector(s) and it is causing one(or more of) them to be stuck open. I would have to ride in it to really see and feel the problem. "
Do ya'll think he is correct about that?
Old Jul 12, 2002 | 03:50 PM
Heavy Pee's Avatar
I installed the feul filter and that did not fix the problem. Now I am checking the ignition components. Would that bethe cause of this?
Old Jul 12, 2002 | 07:57 PM
rioninja's Avatar
Before you do ANYTHING else, find out what code the computer is throwing. It will tell you 100% for a fact what is going wrong.
Old Jul 12, 2002 | 08:11 PM
jetli6969's Avatar
New User
Default Re: Car almost stalling. Need help Tech's. (RioNinja)
mines doing the same thing, i need a new o2 sensor. code 1
Old Jul 12, 2002 | 08:44 PM
Heavy Pee's Avatar
Default Re: Car almost stalling. Need help Tech's. (jetli6969)
My friend said that usually the O2 sensor it would be rough as soon as i get on the gas and sometimes at idle . My car idles fine drives fine when i drive normal , but when i floor it in first or second it will jerk and almost stall , CEL comes on then it goes away.
Old Jul 12, 2002 | 09:39 PM
Heavy Pee's Avatar
The computer threw no code.
Old Jul 12, 2002 | 10:02 PM
EF_LSVtec's Avatar
Here's another shot...when I did my swap, idle is a bit rough runs ok but when I floor the gas pedal engine boggs like its drinking too much gas and it wants to spit it out...We retraced the vacuum hoses connection, apparently they were interchanged then we plugged any hose thats not connected to anything...it solved the problem...I hope this solves yours too...
Old Jul 12, 2002 | 10:12 PM
WickedZ's Avatar
try turning up the idle a little higher...
Old Jul 13, 2002 | 08:55 AM
mos21's Avatar
Default Re: Car almost stalling. Need help Tech's. (blitzcrx)
heres another trick.. try reseting your ecu sometimes that helps.. or try using a friends ecu. just to see if thats the problem. if it idles good then why would it be your filter ? its just when it hits vtec right? then it should be only your computer
Old Jul 13, 2002 | 10:07 PM
Heavy Pee's Avatar
Default Re: Car almost stalling. Need help Tech's. (mos21)
What do I do to check if the feul pump is working or not??
jdm mini me
11
Mar 28, 2010 05:22 PM
jurenic
Oct 28, 2008 01:14 PM
spyda man
Aug 21, 2007 09:31 AM
andlude
Feb 7, 2003 06:01 PM
GSR44
Jun 27, 2002 10:01 AM
