timing troublz
Old Apr 19, 2008 | 12:35 PM
daniel990836's Avatar
From: born and raised in norcal, livin in houston, tx, 77073
Default timing troublz
i just recently changed the head gasket so i removed the head and put the new gasket on. then i remember i forgot to put the #1 piston to TDC before installing the head. so i Put it to TDC then aligned the camshaft to its proper areas and i check the distributor and its odd because u know how theres an indention in the camshaft where i guess the distributor lines in with so the cam turns the rotor? well it wont line up with it. like instead of lining up with cylinder #1 it lines up with cylinder #3. can some one help?
Old Apr 19, 2008 | 12:43 PM
Former User's Avatar
Default Re: timing troublz (daniel990836)
Double check that the crankshaft and camshaft are perfectly synchronized at TDC. To do this, properly align the single white TDC mark on the crankshaft and the UP and side marks on the camshaft gear.
Old Apr 19, 2008 | 12:51 PM
Default Re: timing troublz (RonJ@HT)
ok imma go give it a shot RIGHT NOW and get back to u thank u
Old Apr 19, 2008 | 01:08 PM
What year Civic? If it would help, I can post a diagram showing how to set the cam and crank at TDC.
Old Apr 19, 2008 | 01:15 PM
so i line it up with the dash mark on top thats painted white or the one on the crank shaft pully on the side thats a white square?
oh lol its d16z6 95 civic si hb
Old Apr 19, 2008 | 01:21 PM
oh and sorry to be a bug but is my camshaft supposed to be able to turn all the way around manually? cuz right now its no letting me it gets stuck
Old Apr 19, 2008 | 01:24 PM
Don't force it. A valve may be colliding with a piston. Try turning crank to free up cam.
The pictures should help with TDC:
Old Apr 19, 2008 | 01:30 PM
alright time to test it out thank u hope that was the problem
Superoofer
Honda Civic (2001 - 2005)
Jan 8, 2018 11:41 PM
stackz
Feb 17, 2012 10:50 AM
chadmasterc
Nov 24, 2005 11:32 PM
chadmasterc
Nov 22, 2005 06:25 PM
chadmasterc
Nov 19, 2005 08:22 PM
