timing troublz
Location: born and raised in norcal, livin in houston, tx, 77073
timing troublz
i just recently changed the head gasket so i removed the head and put the new gasket on. then i remember i forgot to put the #1 piston to TDC before installing the head. so i Put it to TDC then aligned the camshaft to its proper areas and i check the distributor and its odd because u know how theres an indention in the camshaft where i guess the distributor lines in with so the cam turns the rotor? well it wont line up with it. like instead of lining up with cylinder #1 it lines up with cylinder #3. can some one help?
Re: timing troublz (daniel990836)
Double check that the crankshaft and camshaft are perfectly synchronized at TDC. To do this, properly align the single white TDC mark on the crankshaft and the UP and side marks on the camshaft gear.
so i line it up with the dash mark on top thats painted white or the one on the crank shaft pully on the side thats a white square?
oh and sorry to be a bug but is my camshaft supposed to be able to turn all the way around manually? cuz right now its no letting me it gets stuck
Superoofer
Honda Civic (2001 - 2005)
01-08-2018 11:41 PM
