Suspension & Brakes Theory, alignment, spring rates....
What's going on here? Problem?
Old Apr 19, 2008 | 12:05 PM
A's 94 GSR's Avatar
BG-33P
Default What's going on here? Problem?
Looked fine yesterday and then today I popped the hood to do some work and found this:
..I hope its nothing major.
Old Apr 19, 2008 | 03:30 PM
egsleepercivic's Avatar
looks like yo forgot a washer when they were installed or the washer broke. should be ok
Old Apr 19, 2008 | 04:18 PM
A's 94 GSR's Avatar
BG-33P
Default Re: (egsleepercivic)
I hadn't messed with the suspension in over a month or two. I don't have to worry about anything do I?
Old Apr 19, 2008 | 05:04 PM
PseudoScience's Avatar
You're kidding right? He does not have any rebound dampening as the spring extends.
I've done what you've done before. You'll need to remove the spring and shock, and reinstall the rubber grommets and washers, and collar in the right order. Pick up a Haynes Manual, it will show you the correct order. More or less you need to fasten the top of the shock shaft to the upper spring hat.
Old Apr 19, 2008 | 05:25 PM
A's 94 GSR's Avatar
BG-33P
Default Re: (PseudoScience)
I just bought a haynes on ebay. Is it bad to ride like this, or should it be fixed asap?
Also, what made it do this? Like I said, it was fine for several months and then all of a sudden I noticed it when I popped my hood to do some maintence.
Old Apr 19, 2008 | 07:56 PM
blinx9900's Avatar
Default Re: (A's 94 GSR)
fix it, looks like you forgot to put the washer on that goes on the shaft, the washer that the top hat sits on...
Old Apr 19, 2008 | 09:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PseudoScience &raquo;</TD></TR><TR><TD CLASS="quote">You're kidding right? He does not have any rebound dampening as the spring extends.
I've done what you've done before. You'll need to remove the spring and shock, and reinstall the rubber grommets and washers, and collar in the right order. Pick up a Haynes Manual, it will show you the correct order. More or less you need to fasten the top of the shock shaft to the upper spring hat.</TD></TR></TABLE>
I meant he should be ok, as in it doesn't look like he did any damage. he just needs to replace/add a washer . sorry for the misunderstanding
*edit* #14 is what you are missing/broken
http://slhondaparts.com/browse...=true
Old Apr 20, 2008 | 05:05 AM
johnlear's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A’s 94 GSR &raquo;</TD></TR><TR><TD CLASS="quote">I just bought a haynes on ebay. Is it bad to ride like this, or should it be fixed asap? Also, what made it do this? Like I said, it was fine for several months and then all of a sudden I noticed it when I popped my hood to do some maintence.</TD></TR></TABLE>
Until you fix it you have no damper function and the handling will be dangerous (just like you had a completely blown 'shock', i.e. damper). You'll have to pull the whole coil-over out and dismantle it to see exactly what's wrong.
By the way, your tower brace is rubbish...
Azimmer
Suspension & Brakes
22
Jun 18, 2012 12:18 PM
beanbag
Suspension & Brakes
29
Jan 12, 2009 12:43 PM
7808
Suspension & Brakes
Apr 12, 2007 10:45 PM
teg92
Apr 25, 2002 02:04 AM
joelsolers
Aug 17, 2001 09:53 AM
