How much torque on ARP 1/2" head studs?
Old Apr 19, 2008 | 08:00 AM
nitroice40's Avatar
Default How much torque on ARP 1/2" head studs?
Thoes of you running 1/2 head studs in your B series motors how much do you torque the studs?
thanks
Old Apr 19, 2008 | 08:16 AM
Ahknodd's Avatar
Default Re: How much torque on ARP 1/2" head studs? (nitroice40)
I run ARP head studs in my D series and they gave me a torque of 60 ft/lbs. on the nuts. You only install the studs finger tight and then torque the nuts to the 60 ft/lbs. Also I had a little problem with my studs not showing enough through my nuts, so they said as long as 3/4 of an inch are in the block then I am good.
I don't know if your specs will be the same as mine, so I would just give em a call. Their number is 1-800-826-3045. I called em and they're really helpful. Good luck man.
Old Apr 19, 2008 | 03:36 PM
nitroice40's Avatar
Default Re: How much torque on ARP 1/2" head studs? (Ahknodd)
I called today but they were closed
Old Apr 20, 2008 | 06:39 AM
Ahknodd's Avatar
Damn, of course they are. sorry man, I guess just wait till monday.
Later...
Keenor
Feb 17, 2011 09:18 AM
nitroice40
Apr 19, 2008 05:19 PM
ivt-t
Feb 8, 2007 09:15 PM
adam8103
Mar 21, 2006 02:53 PM
LudEcrous
May 4, 2004 01:47 PM
