clutch / transmission problem
Old Apr 18, 2008 | 09:46 PM
obuhmyuh's Avatar
Default clutch / transmission problem
i was driving to work today and i lost clutch pedal pressure and was unable to select gears. Clutch is almost brand new (about 2 months driving on it), and my clutch master cylinder was completely full. (Kind of a brownish color though, not the usual golden).
I ordered a new clutch slave cylinder from kragen.
Does anyone have any other suggestions?
Old Apr 18, 2008 | 10:07 PM
V-tecman37's Avatar
Default Re: clutch / transmission problem (obuhmyuh)
Bleed the system and check for leaks in the line.
Have someone step on the clutch pedal while you pull back the boot covering the slave cylinder and and see if the slave cylinder moves at all.
If all else fails after you replace the slave theres a 99% chance its your Master. Good luck.
Old Apr 18, 2008 | 10:22 PM
obuhmyuh's Avatar
Default Re: clutch / transmission problem (V-tecman37)
a leak in the clutch line would lead to my master cylinder going dry, when i opened it it was full. but you think its my master cylinder and not my slave?
Old Apr 18, 2008 | 11:37 PM
obuhmyuh's Avatar
bedtime bump
Old Apr 19, 2008 | 09:57 AM
obuhmyuh's Avatar
ttt^^^
Old Apr 19, 2008 | 01:47 PM
V-tecman37's Avatar
Change the slave first and if you still have the same prob its time 4 a new master.
Old Apr 19, 2008 | 02:14 PM
obuhmyuh's Avatar
i replaced them both, QUITE THE PAIN IN THE *** BY THE WAY (master cylinder mainly) working under the dash... seems to be fixed thanks for now! haha
gooblinn258
Jan 18, 2014 05:02 PM
Miracle11
Feb 13, 2011 06:38 PM
hYbRiD EeEkAy
Aug 7, 2008 11:27 AM
crxricer66
Dec 1, 2007 07:58 PM
97tegGS
Jun 10, 2005 05:13 AM
