spray on high compression motor
Old Apr 18, 2008 | 09:45 AM
jksmith's Avatar
Default spray on high compression motor
here is my setup on my car now and its high compression 12.x something dont know exact but, was wanting to know how much Spray i could run safely, what all should i do, would like to run 75-100 shot
-LS Block
-LS Rods
-CTR Pistons
-B16 head
-Crower Valvetrain
-ITR Cams
-NGK Plug Wires
-Skunk2 Intake Manifold
-AEM Fuel Rail
-Adjustable FPR
-Walbro 255lph Fuel Pump
-stock gsr injectors
Old Apr 19, 2008 | 07:26 AM
jksmith's Avatar
come on nitrous gurus!!
Old Apr 19, 2008 | 09:00 AM
QuickDxEk's Avatar
Are you wanting to run dry or wet kit??
Old Apr 19, 2008 | 10:01 AM
EASY101's Avatar
* B A N N E D *
I wouldnt spray **** on it untill its tuned for the nitrous....thats pretty high compression. I would stay on the safe side.
Old Apr 19, 2008 | 11:35 AM
jksmith's Avatar
i have a dry kit, thinking about running a 50 or 75 shot
Old Apr 19, 2008 | 11:39 AM
totsie7944's Avatar
Default Re: (jksmith)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jksmith &raquo;</TD></TR><TR><TD CLASS="quote">i have a dry kit, thinking about running a 50 or 75 shot</TD></TR></TABLE>
I definately would not run a dry kit on a high compression motor...from what I've read you wanna stick with a wet kit on that kind of setup. But I am not a expert on this.
Old Apr 19, 2008 | 02:09 PM
jksmith's Avatar
whos the nitrous experts around here ill pm them...
Old Apr 19, 2008 | 09:20 PM
count me out's Avatar
* B A N N E D *
i dont think youre over 11:1 with that setup, but yeah, get it tuned.
spray is wack, incase you didnt know.
Old Apr 20, 2008 | 06:30 AM
jksmith's Avatar
bump again for a Nitrous GURU
Old Apr 20, 2008 | 07:51 AM
Sr420Det's Avatar
with that kind of compression I wouldnt run over a 50 shot plus your still running oem pistons. Either way your going to have to have some way to retard ignition and add fuel.
You could increase fuel pressure and retard at the disturbertor but then ur asking for it. You also need some colder plugs to spray. Yeah nitrous is pretty wack, I just went from a turbo to a 50 shot and hate it. I like spraying but that stuff cost 40 bucks to fill up a 10lb tank and you have a 1200 psi bottle sitting in your car, proabably not the safest thing especially if your not running your safety valve out of the car.
Old Apr 20, 2008 | 02:28 PM
B20UnderPressure's Avatar
Default Re: spray on high compression motor (jksmith)
I had a built gsr motor with ctr pistons and a 55 dry shot. I had my engine tuned on motor. I never had any problems at all but, you will need to retard timing. Also don't use platinum spark plugs with nitrous. Put some Ngk BKR7E spark plugs in your engine. Those plugs are colder stage than stock and can take the heat better than factory. Definetely get your engine tuned before using nitrous cause you sure don't want to be running lean. If you're running lean on motor and then try to use nitrous your probably not going to have a happy ending.
Old Apr 20, 2008 | 05:11 PM
ramhorn15's Avatar
Default Re: spray on high compression motor (B20UnderPressure)
I have sprayed on 12:5 compression before a 100-shot but I had a separate fuel system for it and it was on 112 race gas and tuned for the shot. I had digital 6 msd box for on the shot it would retard the timing and off the shot the timing would be different. It was activated by a toogle switch you hook up to the msd box. Remember tunning is key and I had a direct port shot and I would spray on a wet shot instead of dry. Be careful this is not a shot you want to play with especially with compression that high. You must have a good turner who knows what he is doing.
le0ftw
Mar 24, 2007 10:44 PM
nylshatch
Dec 10, 2006 12:09 PM
mikkey1
Oct 3, 2006 01:08 PM
boosted k20
Jul 26, 2005 07:46 PM
RTW DC2R
May 30, 2002 07:45 AM
